advice on rescuing peggy sue
Discussion in 'The Hokey Ass Message Board' started by crackernutz, May 12, 2009.
  1. crackernutz
    crackernutz
    from tx
    Took her for a spin the other night to get some starbucks. ya ya let the jokes begin. Anyways, the engine started sputtering like it was out of gas..my fuel gauge doesnt' work.. could be out of gas i guess but i dont think that's the case. Anyways pulled her into a church parking lot and walked about half a mile to get some gas. poured some in the carb...and the tank. she starts for a second or two then dies. over and over . pour gas in the carb burns off that gas then dies. any advice? i'm going to try and rescue her tonight.
  2. SlamCouver
    SlamCouver
    from Brazil, IL
    Clogged fuel line or jet.
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    or the fuel pump took a ****
  4. crackernutz
    crackernutz
    from tx
    well that ****s considering i'm fixing to do an engine swap. i really dont want to have to pay to have the car towed.
  5. Chris
    Chris
    Disconnect the fuel line after the pump. Crank it with the line in a gas can or somthing and see if it shoots fuel. If so, you have a carb problem. If not, either pump is shot or it's outta gas. Remember, it takes a little while of running to get gas from the tank to the carb if it's been run dry. You might also try filling the bowl of the carb with gas, then it should run for 20 seconds or so.
  6. ryno
    ryno
    try checking your fuel filters.
    they may be one in back at your tank also.
  7. oilslinger53
    oilslinger53
    from covina CA
    fuel pump. fuel filter, fuel pickup, clogged jet
  8. BigBlockMopar
    BigBlockMopar
    Just another tip;
    Check the oillevel, in case the pump diaphram ruptured and is now letting fuel enter the engine crankcase.
    Good luck.
  9. DE SOTO
    DE SOTO
    Starbucks & an Engine swap for the Old Caddilac ?
    Whats in It Now & what do ya plan on swapping in ?
    It Prolly just knows you about to Rip out its Heart & put a Chevy in it.
    You Know Dinosaures play Dead when they see the end is near :D
  10. SlamCouver
    SlamCouver
    from Brazil, IL
    Haha, awesome.
  11. crackernutz
    crackernutz
    from tx
    no SBC or BBC's for me
    going with a 472 at least it's cadillac.
  12. DE SOTO
    DE SOTO
    Thats not an easy swap my Friend.
    Guy i know did a similar swap into his '57 Caddy .. EVERYTHING was a challange & EVERYTHING was in the way.
    Oil Pan sump was ALL wrong, Oil Pump hit the frame, Dan didnt clear steering, Exhaust was to wide & hit control arms...
    Come to think of it he started it about 5 years ago & i STILL havent seen the car run.
    Be sure to re- check EVERTHING before you jump right in :)
  13. All works pretty well if you use El Do parts.
  14. shortbed65
    shortbed65
    from ne Ill
    I like the answer from Chris but I'd like to add -- the steel fuel line on a 1960 Chevy is in 3 pieces from the factory, a splice above the rear axle , and a splice near the rear of the front fender , in between those lines is a 5/16" x 3" fuel hose , maybe the same design on Peggy Sue , old rubber collapses with suction
  15. Piewagn
    Piewagn
    Rotted/perforated fuel line?? Will **** air, not allowing enough fuel volume.
  16. crackernutz
    crackernutz
    from tx
    could be. I went and did some more work lastnight to try and figure out what's going on. i filled up the bowl and it ran for a good 20 seconds ,but died when the gas in the carb was drained. pressed gas just got a ****ing sound and the engine died. disconnected the fuel line after the fuel pump and no gas was squirting out when the engine was cranking.
  17. Degreaser
    Degreaser
  18. _charles_
    _charles_
    from Tampa, Fl
    AAA. Best $$$ ever spent.
    I went to the the "undesirable" side. 2008 5.3L Vortec, Fuel injected, drive by wire. It's taken 3 months, and should be done in a few weeks. Alot of challenges, especially since I kept the stock frame and steering.
    Charles
