Advice Options ~ Is it worth using a 1953 Dodge frame w factory straight axle?
Discussion in 'The Hokey Ass Message Board' started by MarkzRodz, Dec 10, 2009.
  1. MarkzRodz
    MarkzRodz
    I'm building a custom '46 Dodge truck. I just found a 1953 Dodge frame, it's rolling, complete & a decent frame with all the factory straight axle intact. It has juice drum brakes.
    What options are available to upgrade/rebuild this front end ? I have a modern rear end that I can install.
    Or should I pass and keep on the lookout for a T Bucket frame and front end ?
  2. trased1
    trased1
    If you keep the stock front end, look up rustyhope.com. Has a disc brake kit for these trucks. I'm working with him on my truck now.
    Good luck.
  3. 49ratfink
    49ratfink
    yer kidding right?
  4. MarkzRodz
    MarkzRodz
    Talk to me RFink,,,communication is the key.
  5. MarkzRodz
    MarkzRodz
    Wow,,Thank You!
    I want to keep a straight axle but I want to upgrade to safer brakes too as well as any steering upgrades. It has to be Hamb friendly as much as possible. I thought T Buckets used the old Ford straight axle set up? What's up with RatFink?
