Technical Advice?
Discussion in 'The Hokey Ass Message Board' started by Christie, May 5, 2018.
  1. Christie
    Christie
    background: 1955 ford fairlane, 272 y block 2 barrel
    Was running just fine till oneday I started her and she just died out.
    Things I’ve tried so far....
    Installed new fuel pump
    Ballast resistor
    New points and adjusted
    New ignition coil
    New voltage regulator
    New condenser
    Rebuilt carburetor
    New gapped plugs
    New battery
    That’s all I can recall atm of what I did.
    So at this point, she starts but will die out if I don’t keep foot on accelerator. Advice???? I’m at a loss
  2. studebakerjoe
    studebakerjoe
    Will it keep running if you keep foot on accelerator? My first thought was if that was the case you had a vacuum leak somewhere.
    greaser64 likes this.
  3. fiftyv8
    fiftyv8
    from CO & WA
    Frustrating as it is, best keep chipping away.
    It sounds like you have done all the things that can be thought of other than new plug leads and air filter.
    I had a buddy who never changed is air filter, then one day it just would not let that engine run and it was the last thing you would think of as the culprit. It would idle but once under load it would just die...
    Best of luck and I hope it is the air filter for your sake.
    grifcarnut likes this.
  4. fiftyv8
    fiftyv8
    from CO & WA
    Yeah, vacuum leak where a manifold gasket has decided to fail.
    Do some reading about vacuum gauges on the internet and how they can be helpful in discovering some engine issues.
  5. kursplat
    kursplat
    by "died out", you mean have never been able to get it started since? or can start it, she just dies?
    Truck64 likes this.
  6. Christie
    Christie
    Yes, it will keep running as long as foot is on pedal
  7. Christie
    Christie
    She starts, just dies out if not pressing on pedal
  8. Christie
    Christie
    I changed air, fuel and oil filters. Lol just forgot to list that too
  9. Christie
    Christie
    Ok, going to check on vacuum. Any other ideas, keep ‘me coming. Lol I’m willing to try everything at this point
  10. studebakerjoe
    studebakerjoe
    I would check around where the intake gaskets are as well as the carburetor to manifold gasket.
  11. studebakerjoe
    studebakerjoe
    Try spraying some wd40 or carb cleaner on those areas while keeping it running. If it speeds up a bit you should have found the leak.
  12. studebakerjoe
    studebakerjoe
    You can also get a bit of a leak around worn throttle shafts, so I would check that too.
  13. Boneyard51
    Boneyard51
    An old back yard trick is to rev the engine up and close the choke completely and open the throttle wide open. You may have got some junk stuck in your carburetor, this may pull it through. Bones
    Terrible80 likes this.
  14. fiftyv8
    fiftyv8
    from CO & WA
    I use a piece of old hose, with one end to me ear and the other as a probe to move it around the upper engine area and listen for louder than normal air ****ing which can some times help to pin point a place of vacuum leakage.
    Don't cost anything and similar to the WD40 trick is a good starting point.
  15. Until the last line of your opening post I was thinking the primary wire from your distributor had a break or bad connection. Since you have fuel, spark and air, I have to go with the vac leak consensus. Stop spending money on parts and just spend a little time on tracing the possible leak. I prefer a light weight oil, in an oil can, like diesel or mineral oil. It's messier than a spray but you can easily put it on very focused places. Start with the gasket between the carb and intake, the carb shaft, then the intake to head gaskets. When the engine is stumbling, the fluid will temporarily fill the leak and should smooth things out. Next check the vac hoses. The older engines don't have many but it only takes one. And by "check", I mean you take every one off and inspect for cracks or splits, mainly at the ends, but sometimes there can be wear or a split somewhere in the middle. I once had a split around the cir***ference of a hose at the barbs of a fitting. The more I tightened the worm drive, hose clamp, the more I split it. The problem was hidden to me and only a R&R could find it. You have to remove the hoses to inspect them and replace any that are damaged or hardened from age.
    Good luck and keep posting about how and what you find. There is a huge brain trust here that can and will help.
  16. No one has mentioned the Vacuum Advance on the dist. If that diaphragm goes bad it will have the symtoms described.
    Hnstray, Truck64 and fiftyv8 like this.
  17. fiftyv8
    fiftyv8
    from CO & WA
    Good point, I had that exact vacuum advance problem years ago on an early Falcon.
    Old wolf likes this.
  18. crminal
    crminal
    Early load-o-matic distributor advance gremlin. Bit me once and changed to the 57 and later distributor.
    All good now.
    Truck64 and Old wolf like this.
  19. Hollywood-East
    Hollywood-East
    What carb? I've had Many carbs that just need the p***ages cleaned, sitting an poop fuel these days makes it a Much more reoccurring problem! Sounds like a clogged p***age to me..
  20. Engine man
    Engine man
    from Wisconsin
    Check vacuum advance and vacuum leaks. Y blocks are notorious for intake gasket leaks. Try a different source of fuel in case the fuel in the tank is bad . Connect the fuel pump to a hose in an external fuel container.
  21. Hard to diagnose from a distance. Ive had engines that wouldn't run correctly. and it was sometimes a combo of several things. stuff like a loose timing chain. Bad powervalve. bad vacuum advance and frozen centrufical advance. Best to get a 57 and newer dist for your Y block. find a large flange 4 BBl intake that's a great upgrade for any Y block. heads 037.JPG
  22. Truck64
    Truck64
    from Ioway
    Did '55 have Load-o-Matic distributor? They are kind of tricky, they depend on the special carburetor venturi vacuum for the advance, and will not run right otherwise.
  23. shoebox13
    shoebox13
    I would try fresh fuel + clean inspect carb. Rebuild as needed. Todays fuel is awful as someone else mentioned.
    Sent from my SM-G930V using Tapatalk
