Hot Rods Advise needed for my 46 gmc drop spindle
Discussion in 'The Hokey Ass Message Board' started by Joseph barbioni, Sep 22, 2024.
  1. Joseph barbioni
    Joseph barbioni
    IMG_1327.jpeg IMG_1325.jpeg IMG_1324.jpeg IMG_1327.jpeg IMG_1329.jpeg Hey guys, i am thinking that the machined taper on my 2” drop spindle is to large causing the spindle sit way to low on the lower balljoint. Any thoughts ? Or anyone else have that issue in the past.
  2. Zuffen
    Zuffen
    from Sydney
    You have it in one. There shouldn't be room for the spacer above the nut.
    Only solution is filling the hole and starting again or (as I would do) return the spindle as it isn't machined correctly.
  3. Joe H
    Joe H
    Wrong ball joint will also look like that, it needs to come apart!
  4. Onemansjunk
    Onemansjunk
    from Modesto,CA
    That’s your problem.
