1952-59 Ford Aerostar Coil spring prices
Discussion in 'Off Topic Hot Rods & Customs' started by JeffB2, Apr 1, 2020.
  1. JeffB2
    JeffB2
    from Phoenix,AZ
    Navyford likes this.
  2. bobss396
    bobss396
    Mine were $50 delivered on Amazon, back 5 years ago. I tried to sell them years ago since I had them in the car shortly, shipping was close to $40 so I still have them.
  3. Texas57
    Texas57
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    With so many folks being happy with the Aerostars on a lot of forums and praising the ride and handling with the switch to a progressive spring,what made you remove them ?
  5. Navyford
    Navyford
    There’s a couple pick and pulls around my area that have aerostars on the lot. I can always pull them if people are looking for them. It’s got to be cheaper to do that, right?
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    The Link I posted above for Rock Auto has them new for $40.79 almost not worth buying used ones.
    Navyford and 54vicky like this.
  7. Navyford
    Navyford
    true being it’s a new product. Shipping for me is $18. I looked at the prices and it’s around $17.50 if I pull them locally.
  8. bobss396
    bobss396
    There are better springs than the CC850, like the CC851. But try telling that to the sheeple. They were simply too short and my front tires (215/75-15) rubbed on normal turns.
  9. okiedokie
    okiedokie
    from Ok
    The 851’s don't have the flat end.
  10. BruceMc
    BruceMc
    from Alaska
    Same here. They're listed at $70 on Amazon Prime now (CC850s). Still hard to beat that deal - new, ready to install, and shipped to your front door for free.
  11. Flattop Tiki
    Flattop Tiki
    CC850 are going for $175CAD on Amazon.ca as of today! :eek:
    I bought mine last September, the AC Delco branded ones, pair cost me $65CAD, I believe the Moogs were around $90CAD when I ordered last.
    Looks like we'll only see Aerostar coils in salvage yards sooner than later.
  12. BruceMc
    BruceMc
    from Alaska
    I'm tempted now to buy another pair just to stash away for the future.
    eta: I just did. Today's price was down to $59.26 with Prime.
    JeffB2 likes this.
  13. Texas57
    Texas57
    did you also have dropped spindles?.....and was it the 850 or 851?
  14. okiedokie
    okiedokie
    from Ok
    On my 55 with dropped spindles both the 850 and 851 were too low. There was very little difference between the two springs.
  15. 40cpe
    40cpe
    from Star, MS
    okiedokie, Have you found a way to raise your front suspension? Remove dropped spindles or use longer springs, or insulator bushings? I'm in the same predicament looking for a solution.
  16. okiedokie
    okiedokie
    from Ok
    Installed the original springs. I would like it about 1” lower so may cut a coil but just going to put some miles on it for now
    40cpe likes this.
  17. JeffB2
    JeffB2
    from Phoenix,AZ
    This should work https://www.energysuspensionparts.com/universal-coil-spring-isolators.asp Check to be sure but I think your spring diameter is a hair over 4" maybe part # 9.6101 ?
  18. 56longroof
    56longroof
    I have Versailles spindles with Aerostars on my wagon. No issues at all and drives great. But I'm running stock wheels with 670-15 tires. I had to cut the bump stops a bit but I never get any tire rub or bottoming out.
    guthriesmith and JeffB2 like this.
  19. bobss396
    bobss396
    850, stock spindles. The disc brake conversion may have moved the wheels out a bit.
  20. evintho
    evintho
    Just ordered a set from Rock Auto. $19 to ship to California. Under $70 total....good deal!
    bobss396 likes this.
  21. jimmy six
    jimmy six
    I have them because I didn’t want to change the spindles to lower it. Needed 2 different energy suspension spacers to make it level. They were for Toyota pickup rears. The Aerostars are different in a road dip because of the compound wound style but I live with it.
    After I had it done I saw where a few guys removed the rivets on the lower a-arms and bolted in 2 to 2-1/2” spacers so all stock components were kept.
  22. steveodeluxe
    steveodeluxe
    Anyone want to pick up a set in South New Jersey area? Email me, I’m not on here as much. I work in healthcare and am just fried most nights. Steveodeluxe@gmail.com
