Hot Rods Afb shafts
Discussion in 'The Hokey Ass Message Board' started by pbr40, Feb 9, 2024.
  1. pbr40
    pbr40
    from NW Indiana
    I’ve looked around with not much luck. I have a pair of afbs that the throttle shafts have some “play” in. Does any one make an oversized shaft or should I even worry about this? Thanks
  2. Oneball
    Oneball
    Depends how bad they are, will start to give idle and very low speed issues if they’re really rough.
    You can ream the hole in the carb and fit a bronze bush.
  3. Ericnova72
    Ericnova72
    from Michigan
    Generally, it's not the shafts that are worn, it is the softer aluminum carb base.
    Fix is ream and bronze bush the carb body shaft holes and re-use the existing shafts.
    Rochester Q-jet's are the same way.
    pbr40 likes this.
  4. carbking
    carbking
    The genuine Carter AFB's were set up with looser clearances than Holley or Rochester. That large aluminum throttle body has to expand when hot. If the shafts are too tight, they will bind. Be careful about fixing a problem that may not exist.
    Jon
    Truckdoctor Andy, pbr40 and Bob Lowry like this.
  5. pbr40
    pbr40
    from NW Indiana
    Ok I over looked that!!!! By all means they aren’t sloppy just have a bit a play. Thanks
