Technical AFR gauge with ZOOMIES
Discussion in 'The Hokey Ass Message Board' started by Larry Kirwan, Feb 13, 2025.
  1. Larry Kirwan
    Larry Kirwan
    Morning, I'm wondering if anyone has ever found a way to use a AFR gauge with Zoomie headers (NO I'm not drilling holes in ceramic headers), I just installed tripower BIG 97 strombergs on a mild 355" SBC, starts and runs strong, but running real rich at idle, pic is 10-15 minutes idleing, Thanks for any direction. 100_0760.JPG
    guthriesmith likes this.
  2. Dave G in Gansevoort
    from Upstate NY
    I have an older Innovate afr meter. It has a clamp on device that holds the lambda sensor at the end of the exhaust pipe and sticks inside the pipe about 5 or so inches to make sure it is getting exhaust gases and not air from the outside. I’ll see if I can find it later today and get a picture for you. Last time I saw it, it wad on an upper shelf that I might not be able to get to currently.
    Tickety Boo likes this.
  3. Jmountainjr
    Jmountainjr
    There are several different styles of clamp on attachments to hold an AFR sensor.
  4. Tickety Boo likes this.
  5. Larry Kirwan
    Larry Kirwan
    I've seen many clamp ons, but I'd have to change 8 times for every cylinder? I guess that may be the only way-even tho every cylinder would prob be a little different because of manifold flow.
  6. Jmountainjr
    Jmountainjr
    If you want to be able to read a bank at a time, and if you don't mind some fab work, it wouldn't be that complicated to make a slip on log style manifold with the sensor threaded in the end.
    Almostdone and Larry Kirwan like this.
  7. Tim
    Tim
    from KCMO
    If it’s just for tuning any reason you couldn’t swap exhaust, tune it and put the zoomies back on? Sbc isn’t exactly the hens teeth of exhaust options?
  8. Larry Kirwan
    Larry Kirwan
    That's not a bad idea....
  9. Blues4U
    Blues4U
    from So Cal
    Of course the change in exhaust restriction is going to change the air fuel ratio while you have the manifold installed vs the zoomies.
    Truckdoctor Andy and 2OLD2FAST like this.
  10. 38Chevy454
    38Chevy454
    I agree the clamp-on sensor that sticks in the end a few inches would get you pretty close. You could swap cylinders once you get it more dialed in, just to confirm the values are approx equal; especially side to side.
    Have you set the idle mixture screws using vacuum? Being so rich you can get it a lot closer to ideal with vacuum, just adjust the mixture screws for maximum vacuum. Are the three carbs all idle circuit? Progressive or straight linkage? Factory 3x2 setups typically had idle only on center carb with progressive linkage to open the end carbs at more heavy throttle.
    leon bee likes this.
  11. Larry Kirwan
    Larry Kirwan
    Yes, all 3 have idle circuits, they are the Big97's with progressive linkage 100_0761.JPG
  12. guthriesmith
    guthriesmith
    I have one in a set of zoomies but put the port in when we built the headers. I “hid” it on the backside so you can’t see it about halfway up the tube. Seems to work ok, but this all happened before I had the headers coated.
  13. Dave G in Gansevoort
    from Upstate NY
    As promised here’s a picture of the Innovate adapter.
    The sensor goes into the boss at the end.
    It then goes into the exhaust pipe and returns the gases into the exhaust stream. This one has been used on things like lawnmower engines, light duty diesels, wood stoves, and various sundry car engines. It’s a good way to get a lambda sensor on an engine for intermittent use.
    leon bee and Tim like this.
  14. distributorguy
    distributorguy
    from MN
    I have a couple of those LM-1 setups and there's one thing I can promise you - that engine is seeing air reversion all the way into the combustion chamber, so using an AFR gauge is going to always be radically skewed and unreliable. Even if you added a 3/8 metal line into the end of the pitot tube (tailpipe clamp) and extended it all the way up to the exhaust gasket, the high temps and close proximity to the head will result in the sensor potentially overheating and failing prematurely.
    Rich at idle is more often a timing/ignition issue. A tri-carb setup like that will run best set up for 20 degrees+ BTDC at idle. If it was my car and had a radical cam in it, I'd likely be running 24 BTDC. Find peak vacuum at idle and you'll find your ideal timing setting. Then tailor the distributor to give you the 34-37 total your engine wants, depending on compression.
  15. Larry Kirwan
    Larry Kirwan
    Thank's I'm gonna start as you say...
  16. Jmountainjr
    Jmountainjr
    Since it's rich at idle, have you checked the carbs while running to make sure that you don't have fuel entering for sources other than idle jet? I have played with a lot of 6X2 and 3X2 carb setups and found most with mechanical linkage (no vacuum actuated) work best with straight (not progressing) linkage.
    19Eddy30 and 2OLD2FAST like this.
  17. Larry Kirwan
    Larry Kirwan
    this carb set-up works with progressive linkage (designed that way) 1 primary-2 secondaries, These are the BIG 97-250cfm ea.
  18. 19Eddy30
    19Eddy30
    from VA
    Even #s of carbs are more Ideal then
    Odd #s of carbs , On V8 , 8 carbs are more the way to go ,
    1 per runner & cylinder ,
    Next 1 carb per 2 cylinders.
    I was fortunately able to talk with engineer that developed 3 carb set up
    For Pontiac, They had to develop specific parts & spec to make 3 carbs work as intended , i Including many hours of development testing,
    & $$$$, same with other manufacturers that use three Carb set up,
    Yes over years many have used & we have seen 3 carbs ,
    Mechanical much better then Progressive linkage On Non OEM set ups .
    Many say fun good No issues,
    But in Reality stick on Dyno , monitoring all eight cylinders , it will be seen the AFR are all over the place , between each cylinder & all threw , Rpms ,from Idle , Cruise to wide open !
    ""Wide open"" more stable & Balanced
    But still not Equal unless you tune for wide open ,,
    Ons SBC , #6 cylinder
    is most time Leanest of the 8 ,
    mad mikey and G-son like this.
  19. Larry Kirwan
    Larry Kirwan
    Thank You, makes sense..
  20. 19Eddy30
    19Eddy30
    from VA
    Not trying to be Negative,
    Just letting you know ,Its difficult even using a dyno to balance AFR across all
    8 cylinders, from I , C , Wot
    Its a lot easier to run 3 carbs on stockish
    Engine,
    O2 afr on Zoomies difficult without drilling for O2 or Egts
  21. G-son
    G-son
    from Sweden
    Yeah, if you want things to work well and be easy to tune you don't want any cylinder to draw air through multiple carbs at the same time, you won't know which one to adjust when some cylinders are tuned right and others are wrong.
    Then again, most carb setups on hotrods seem to be more meant for looks than function, and that's fine as long as you are happy with what you've got.
    ALLDONE likes this.
  22. Hollywood-East
    Hollywood-East
    Random... What type of fuel pump, An whats do You have it regulated to ?
  23. Larry Kirwan
    Larry Kirwan
    2psi
    Hollywood-East likes this.
  24. Larry Kirwan
    Larry Kirwan
    Well, what you don't realize is!!!!!!!!!! I'm running this in a 2,000LB car and trust me a light car with flaws will scare the **** out of you....
  25. Larry Kirwan
    Larry Kirwan
    Really, do you have anything else Negative to say today, I have what I want and BTW this T-Bucket does have GO. 100_0688.JPG
  26. Larry Kirwan
    Larry Kirwan
    low pressure 4-7 electric pump and Mallory reg, set at 2psi, checked with 3 gauges
  27. Joe H
    Joe H
    The type of linkage does not effect idle.
    What is the rpm at idle?
    What is the vacuum at idle?
    Is there power valves involved?
    Tim likes this.
  28. Larry Kirwan
    Larry Kirwan
    I would just as soon not have you trolling my post that I was looking for positive help.....
    Blues4U likes this.
  29. Larry Kirwan
    Larry Kirwan
    Idle is 700
    vac is 13"
    PV shouldn't be involved at idle?
  30. TA DAD
    TA DAD
    from NC
    So jet it down , lower the floats , turn the timing up and add another return spring on the throttle cable for good measure ! oh and turn the temp up also unless it is already at 200 or so.
