Technical AFR Tuning
Discussion in 'The Hokey Ass Message Board' started by jaw22w, Sep 20, 2021.
  1. jaw22w
    jaw22w
    from Indiana
    I installed an AFR gauge and a vacuum gauge in my '26T coupe with an SBC 355. It has a Quick Fuel SL 600 VS carb on an Edelbrock rpm dual plane manifold. I have been making changes and then driving it for a while. Then make another change. I started out with AFR in the 11-13 range in all modes, I have played with every circuit in the carb. My AFRs are now in the 14-16.5 maybe 17 at times at part throttle cruise, depending on the weather. My WOT AFR is about 12-12.5. The engine operates beautifully with this tune. No hesitations, bogs, or lean backfires. I wouldn't want any circuit to lean out any further. Except idle. My problem is I cannot get my idle AFR any better than 12.4:1 and still make the transition off idle good. I can actually get the idle AFR to a little better than 14:1 by leaning out the idle mix screws, and it idles well, but the transition circuit goes lean and starts giving an off idle hesitation. The next size up squirter might fix that hesitation, but I haven't tried that yet. It seems counter-intuitive to economy.
    I wonder if I have worked myself into a corner. Should I start the whole tuning process over, starting with the idle set at 14:1 with the idle mix screws and start richening up the other circuits? It has been about a 5 month process to get where I am. I am really happy with the performance other than the idle AFR.
    What's my next move?
    blowby, Truck64, fauj and 3 others like this.
  2. indyjps
    indyjps
    I commend your tuning dedication, not many folks use a dedicated AFR gauge with a carb.
    If it's healthy at your current idle and transitions well. I'd call it done. Are you just chasing the number?
    It's a modified car, ideal idle for a stock vehicle may not apply.
    WOT and Cruise AFR would be most important to me, multiple cruise mph ( 30-40) and ( 70-80) to cover around town and highway.
    If a squirter change and better idle AFR are the goal, give it a try.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Knowing when to quit is an art in and of it's self.
  4. RmK57
    RmK57
    Next size squirter or the accelerator pump cam. There is a kit you can buy and experiment with. I think my Holley 950 HP uses the pink one.
    jaw22w and Deuces like this.
  5. saltflats
    saltflats
    from Missouri
  6. Truck64
    Truck64
    from Ioway
    Don't mess with jetting or cruise circuit or anything else or start over.
    What do the plugs look like? A rich idle circuit will load them up and foul pretty quick. 12.5 sounds pretty rich for idle. Kinda want to give an engine what it wants versus "chasing numbers", but yeah.
    I'm sure you've seen this page? If not...
    https://www.tccoa.com/d2/members/392bird/tuning.htm
    Deuces and jaw22w like this.
  7. BadgeZ28
    BadgeZ28
    from Oregon
    I have heard of guys changing air bleeds on carbs that have them to fine tune. Sounds like a little more air vs fuel is needed on the primary side.
    Deuces, jaw22w and pitman like this.
  8. jaw22w
    jaw22w
    from Indiana
    Yeah it runs great. Any body that drove it would be happy.
    My background is circle track racing. My carb knowledge consisted of curb idle, idle mix screws and main jets. I didn't care much about the carb as long as it would drive through the pits and run good at 4500-7500 rpm. Now being more into street cars, I wanted to learn more about carbs.
    So I decided to take this carb on for economy. I've read all the books, Vizard, etc., and now have a pretty good understanding of the different circuits. I have gone from about 12 mpg to almost 16 mpg. That's in town driving. This car seldom sees the highway. I just feel that it could be better yet. I'm not really looking for a "number" other than the bottom line MPG number. And I believe the last improvement is to be found by leaning the idle AFR. I know it will idle well at 14:1. I just need to get it transition well. That could however result in less mpg. I think I will give that a try.
    Aerodynamic wasn't in Henry's engineers' vocabulary when they built this car, so that's not helping anything either.
    You are correct, but I don't think I am at that point yet. It takes about 20 minutes to make a tuning change on the carb, then drive it for a couple of weeks, doesn't take much time out of my busy (LOL) schedule. Besides I enjoy solving these kinds of problems.
    AHotRod, loudbang, Truck64 and 3 others like this.
  9. jaw22w
    jaw22w
    from Indiana
  10. scrappybunch
    scrappybunch
    from nj
    Have you tried tuning the vacuum advance, preferably using manifold for vacuum source. Adding more or less "in the can" timing can also alter the a/f ratio at idle.
    You seem to be real close to perfection. My q-jet responded well to tuning with actual numbers.
    Truck64, jaw22w and Deuces like this.
  11. 19Eddy30
    19Eddy30
    from VA
    Sent you a PM
  12. ClayMart
    ClayMart
    There's something to be said about your methodology. But remember that the engine doesn't spend much time idling under most cir***stances. To make much of a difference in fuel mileage I'd think it would have to be idling pig-rich, rolling black smoke out the tailpipe.
    If you're working with something hotter than a stock cam, you may already have the throttle plates open slightly past the transition port to calm down the idle. Since the transition ports provide only a small amount of enrichment for a short period of time, it may not be worth a lot of extra effort. And increasing the accelerator pump volume will probably cost you more in mileage, even though it would likely improve the off-idle feel.
    jaracer likes this.
  13. 19Eddy30
    19Eddy30
    from VA
    On a Chevy V8 always tune your AFR off # 6 (leanest) next is #3 Second leanest cylinder
    Its a balance game to play,
    Most will not go this far in tunning,
    I do not want to burn a piston in 6 or 3.
    -1,5,7 & 2,4,8 run close to same AFRs ,,
    Intake no matter the brand plays a big part of air fuel ratio delivery anything over a stock intake manifold.
  14. jaw22w
    jaw22w
    from Indiana
    I haven't messed with the air bleeds much. I did try up 2 and down 2 sizes from stock on the idle air bleeds, but didn't like either one. But that was with a different combination of everything else. So maybe an idle air bleed increase might help. I'm thinking that might carry through the transition phase, though.
  15. squirrel
    How does the cam profile affect what AFR is needed at idle? I know in the old days, I'd always have to run a rather fat idle on an engine with enough cam to give it a rough idle. This was back when I used a 2 gas ****yzer, looking at CO and HC. It was pretty common to go up to 5% CO to get the transition acceptable, and also keep HC numbers down.
    Deuces, jaracer and jaw22w like this.
  16. jaw22w
    jaw22w
    from Indiana
    I think while in town driving the engine is idling or just off idle more than most people realize.
    This engine is 9.96:1 CR. It has .043 quench. ProMa** 183cc aluminum heads w/64cc chambers, 2.02/1.60. Cam is hyd. roller 215/224@ .050, 284/296 adv, .470/.490 lift on 112 LSA. Probably makes 325-350. Smooth idle, no lope. Trans slot is set at about .020 exposure. Idle speed screw can be turned about + or- 1/4 turn and stay in good relationship to throttle blades. Any gross idle adjustment is done on the secondary throttle stop. I replaced that stupid short set screw with a longer screw so a 1/4" wrench makes it easy.
    Yeah increasing the squirter could very well end up with less mpg. That's why I have resisted doing it. But I'll never know for sure unless I give it a try. I can always change it back. It's not like changing a cam. I would like those plugs to clean up.
    IIRC there are 12 or 13 points of adjustment on this carb. The number of combinations is probably close to infinite. I can play this game the rest of my life.
    Deuces and ClayMart like this.
  17. jaw22w
    jaw22w
    from Indiana
    Yeah, this cam at 215/224 and 286/294 has a lot of overlap. The way I understand it is cams with a lot of overlap usually need a rich idle to overcome reversion, but this is a fairly mild cam that produces no lope and I know it will idle well at 14:1.
    Deuces likes this.
  18. 19Eddy30
    19Eddy30
    from VA
    Cam profile dose affect AFR balance in intake & runner on naturally aspirated more so then forced induction, from idle ,cruise, wot.
    jaw22w likes this.
  19. jaracer
    jaracer
    A couple of thoughts; like others have said, idle mixture doesn't have a large effect on fuel economy unless you idle the engine a lot. One size larger squirters won't have much of an effect unless you are constantly on and off the throttle, which is a fuel economy killer anyway. The last thing is that this thing is getting close to 16 mpg in town, that is pretty amazing.
    jaw22w likes this.
  20. gimpyshotrods
    gimpyshotrods
    Is your fuel straight gasoline, or is it E10?
    The Stoichiometrically-correct ratio for straight gas is 14.7:1
    The Stoichiometrically-correct ratio for E10 is 14.2:1.
    If you can get it to 14:1, you might be rubbing the edge of the accuracy of the gauge and Oxygen sensor.
    AHotRod, Nick O, loudbang and 2 others like this.
  21. seb fontana
    seb fontana
    from ct
    Post pic of the plugs?
    Truck64, Deuces and jaw22w like this.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    The low engine speed operation with your cam, induction , compression ratio , piston & combustion chamber & exhaust system design MAY make it impossible to do any better than you have !? I'll add this , 55 years ago , in college , one of my cl***mates rolled in in a new cobra after spring break , complete with one of those 8- stack ****ographic Weber setups on it ( c'mon you'd a been drooling too) and from that point until the end of the school year , his " mechanic" showed up every couple weeks for " tuning" .....from 300 miles away ( daddy flew him in) As well as that car ran ( & it screamed) it would not vary the tune on its own , no carb ,or cab expert, can .
    jaw22w likes this.
  23. gimpyshotrods
    gimpyshotrods
    What are you running for ignition?
    Automatic or manual? What is your current idle speed?
    AHotRod, Deuces and jaw22w like this.
  24. jaw22w
    jaw22w
    from Indiana
    When I started this project, I bought a range of main jets, IFRs, Air Bleeds, power valves and PVCRs, squirters and pump cams so I would have what I needed. I have three different QFT carbs, a 600VS, a750VS, and an 850DP on different engines. These parts fit them all. I only have the AFR gauge on one of them. I figure after I get to be an "expert":rolleyes: and get the Model T coupe all tuned in I can swap the AFR onto the T roadster and start on it.
    Deuces and G-son like this.
  25. jaw22w
    jaw22w
    from Indiana
    I will get them out this evening an post a pic. I don't know how good of a pic I can get though.
  26. gimpyshotrods
    gimpyshotrods
    Bump the idle up 25rpm at a time and make a note of what that does to the air/fuel ratio.
    jaw22w, Deuces and squirrel like this.
  27. jaw22w
    jaw22w
    from Indiana
    Fuel is straight gas. So 14.7 is stoich.
    I don't understand why my gauge would be "rubbing the edge of accuracy"?
    I can get the idle AFR to 14 easily. I haven't tried, but I could probably get it to 15 or higher.
    Trans is 700r4. 3.89 rear gear w/28" tire. 1900 rpm at 55 mph. I almost never get on the Interstates with it.
    Ignition is Pertronix Flamethrower III. 18 initial +16 mechanical = 34 +14 vacuum @7", all in @2500. NGK 5671A-7 plugs @.035". Taylor wires. Zero detonation.
    Idle speed is about 800-850 in park. 700-750 in gear. Torque converter is one step above stock stall in the 1800-1900 range.
    AHotRod and Deuces like this.
  28. squirrel
    Somewhere you have to make a compromise between economy and driveability. I would make it by running the idle a bit fat, but playing with the squirter might be a better way to go. You can adjust both the size and the duration, so maybe play with a big bigger squirter, maybe not so big a cam?
    anyways, let us know what you end up with, so we can learn...
    AHotRod, jaw22w, Deuces and 1 other person like this.
  29. jaw22w
    jaw22w
    from Indiana
    Well, I got the plugs out, but can't get a pic that would show anything. The ceramic is dark brown and the surface is sooty black and are pretty consistent through all eight. The pics just look like a dark spot. They all show rich as hell. I hadn't looked at the plugs in a while. They certainly verify the 12.4 idle AFR.
    Deuces likes this.
  30. pprather
    pprather
    I admire your hard work in learning this science and testing each solution. Quite a journey. Education is always a worthwhile pursuit.
    I'm not sure how you will know when you've reached your goal.
    From a practical point of view, how many 'around town' miles does this rod do a year?
    On my rod, I drive about 6k miles per year. About , 80 per cent highway. I stopped working on mpg improvements when I averaged just over 20 on a trip of two thousand miles, with a mild/stock 350 SBC.
    Keep us informed of your trials and progress on this project.
    Algoma56 and Deuces like this.
