Hot Rods Aftermarket radiator question
Discussion in 'The Hokey Ass Message Board' started by Christopher26, Jul 6, 2019.
  1. Christopher26
    Christopher26
    Hello everyone and thanks for any help in advance, have a 61 GMC pickup and picked up an aluminum radiator and the new one has ports for a ****** cooler which I would like to use.
    Both port are on the bottom of the rad though not top and bottom like the other ones I’ve seen. Anyway to know which is feed and which is return without the motor running? Still finishing up the motor but would like to run the cooler lines and trying to figure out which one is feed and which is the return line, thanks for any help everyone
  2. HOTRODPRIMER
    HOTRODPRIMER
    To my knowledge it usually doesn't matter. HRP
  3. Christopher26
    Christopher26
    That’s what I was thinking also bc it’s just flowing through and out it shouldn’t matter but wasn’t positive, thanks primer
  4. rusty1
    rusty1
    ...use it if you like, doesn't matter which way you hook it up;...I'd run a separate
    cooler mounted along side the trans on the frame rail where it can get air ,...use 2 short lengths of rubber hose and pre-made hard lines off trans;...less work and keeps heat out of radiator,..been runnin these on over 2 dozen hot rods with no problems.
    lothiandon1940 likes this.
  5. Christopher26
    Christopher26
