Technical aftermarket radiator
Discussion in 'Traditional Customs' started by gdrummer, Jul 22, 2020.
  1. gdrummer
    gdrummer
    hi ya'll. i'm working on a 51 deluxe, 216, 3spd.
    pulled the radiator and it looked pretty clogged so i sent to my local shop that i've used before and had good results.
    so, to recore my rad using my tanks is $550. seems a bit high to me and although i like the idea of saving the original rad tanks, i see that i can get an aftermarket replacement for about $200 less. what i'm finding though is they either wont work with the 216 or they need to be cut to fit or in some cases both.
    so here is the 2 questions i have. has anyone found a direct replacement that bolts in or should i bite the bullet and get the old one rebuilt?
    thanks ya'll
  2. alchemy
    alchemy
    "aftermarket replacement" could be a wide variety of quality. Please elaborate.
    dana barlow likes this.
  3. squirrel
    Used to cost $100 to get a radiator recored, 30-40 years ago. So 550 isn't really out of line....
    of course, I'm too damn cheap to get one done these days.
  4. flatford39
    flatford39
    That's not a bad price at all for a re-core around here. Can't compare it to your whereabouts as you haven't filled out enough of your profile. I paid $400.00 for a re-core of a Model A radiator and it turned out really nice.
  5. i.rant
    i.rant
    If you decide to do an aluminum radiator do your homework. Wide range of quality out there.
    lothiandon1940 likes this.
  6. HOTRODPRIMER
    HOTRODPRIMER
    A brand new Walker copper/br*** radiator will cost you over 700 bucks and is made for your application, expensive yes but it also has a 10 year warranty and I know from experience the radiator in my 1932 Ford is now 33 years old and I have never had a problem with it.
    That will never happen with a aluminum radiator. HRP
    Algoma56, dana barlow and i.rant like this.
  7. harpo1313
    harpo1313
    from wareham,ma
    Ive had nothing wrong with Walker for many years.
    Algoma56 and HOTRODPRIMER like this.
  8. gdrummer
    gdrummer
    ok so i think i'll keep the original. the ones i was looking at were champion aluminum. there were a few on speedway too but you are right, the walker goes about 700-750.
    i'm in tucson az.
    thanks for the input ya'll.
  9. squirrel
    just curious, what shop gave you that quote?
  10. Gman0046
    Gman0046
    I'd be wary of any radiators made in China by small children.
  11. 51504bat
    51504bat
    A new core for the heater the on my '54 Ranch Wagon was $150.00. I could have bought a new off shore one for $110.00 plus shipping but I figured the original tanks were much better than what would be on the cheapy repop core.
  12. gdrummer
    gdrummer
    performance radiator on fort lowell
    squirrel likes this.
  13. Mr48chev
    Take a look at this one from Engineered cooling products, Not any more spendy than one of those with the flat aluminum tanks and if you paint it black it will p*** the quick glance test as being an original.
    I have one of their radiators for my 48 pickup and really like it.
    You would have to change the thermostat housing or use a flex hose with two different size ends as the inlet is 1-1/2 rather than 1-1/4.
    eBay item number:
    323938088271
    Website http://www.speedcooling.com/1948-1954-Chevy-Radiator-V8-SBC-BBC.html
  14. X38
    X38
    Is this oil day again? Oops, sorry, radiator day. Oil day is Tuesday.
  15. bobss396
    bobss396
    Especially if they were making less than 45¢ per hour....
  16. bobss396
    bobss396
    I thought it was residual valve day... my bad....
    X38 likes this.
  17. Budget36
    Budget36
    Champion has a good rep. Search them.
    I guess I'm the only one on this thread that ever bought from Amazon or Walmart....yawn..
    1971BB427 likes this.
  18. thekid1950
    thekid1950
    Wow...you guys a pretty lucky.
    I have a 49 Plymouth Wagon. I live in Upstate NY.
    Leyland Raditor wanted $1550 to recore my radiator.
    I couldn't believe the price.
    I went with a $225 Champion. Fit nice. Cools great
    If it lasts, it'll be a bargin.
  19. lippy
    lippy
    from Ks
    Just had an O/T 70 road runner radiator recored. $750.
  20. gene-koning
    gene-koning
    There is no place within 50 miles (maybe more) of here that will recore a radiator these days. That pretty well reduces the options. Gene
  21. Beanscoot
    Beanscoot
    Was your radiator leaking? If not, what about just getting it cleaned or flushed out?
  22. 1971BB427
    1971BB427
    from Oregon
    I have to ask. What's so special about a '51 Chev radiator for six that it has to be a direct replacement? Can't you just find a decent aluminum radiator with the outlet and inlet the right size, and location, and make it work? I'd think any number of late 40's to late 50's Chevs used similar radiators, and mounting systems, and would be easily used.
    I looked at all the expensive options for V8 swap radiators for late 30's Chevy coupes when I started my build. Then I decided there must be a million places offering radiators for Chev V8's into '32 Fords, so likely very compe***ive pricing. I bought one for a '32 Ford, and it was a snap to make it fit, and works great.
  23. Elcohaulic
    Elcohaulic
    I use the Champion. Once I paint it black, its real hard to tell the difference.. I usually can get them on e bay for $130.00 or so.. Its a good quality unit too..
    bobss396 likes this.
  24. alanp561
    alanp561
    Radiator shop 40 miles from me wanted $650 to re-core the 46 Merc radiator and $250 to re-core the heater. I bit the bullet on the heater but bought a Champion ( $204 ) for the engine bay. Champion's instructions say to use distilled water and/or a 50/50 coolant mix to avoid electrolysis. After a year, seems to be working OK.
  25. bobss396
    bobss396
    I have one in my Ford for 4 years now. Craftsmanship is great and the price was right, got it on eBay. The seller (radiators4less) gives all the dimensions you need, plus free shipping which Champion gets $30 for. I use distilled water, 50/50 Car Quest coolant and use a sacrificial anode where the pet**** goes.
    alanp561 and Budget36 like this.
  26. Casey Riley
    Casey Riley
    from Minnesota
    The 2 shops around here that do recore/ rebuilds are about $600.
    I went cheap and bought a Champion radiator for my 51 Mercury flathead.
    The Champion radiator was a waste of money and effort.
  27. 41rodderz
    41rodderz
    from Oregon
    Holy moly . Maybe I should put my radiators (new and recored ) for sale on here.
