Aftermarket Steering Column Safety Alert
Discussion in 'The Hokey Ass Message Board' started by LIFESTYLZ, May 6, 2013.
  1. Go with Ididit. Made here in the states and excellent quality.
    olscrounger likes this.
  2. StefanS
    StefanS
    from Maryland
    So it wont have the issues in this thread?
  3. Ididit has a quality product. Also a lifetime warranty. This includes the turn signal switch.
  4. StefanS
    StefanS
    from Maryland
    Can they make a custom column? I want to use the factory steering wheel and original turn signal switch since it works perfectly
  5. 31Apickup
    31Apickup
    Why not just cut down the original column, you’ll have to add a bearing to the lower end and mill ( file) flats on it to use DD joint.
    6inarow likes this.
  6. StefanS
    StefanS
    from Maryland
    I was thinking about that. I still may do it. You dont happen to have a source for the bearing do you?
  7. 31Apickup
    31Apickup
    Not sure on the Chevy column, but on 40’s era Fords a common wheel barrel bearing is used.
    rust runner likes this.
  8. vtx1800
    vtx1800
    I used a early 50's Pontiac tube with the org brg at the top (for the horn) and a common "wheel barrow" flanged bearing that I picked up at Bomgaars (read Tractor Supply, or possibly your "big box store") here is a link for McMaster Carr https://www.mcmaster.com/bearings/wheel-axles-bearings-and-reducer-bushings/
    The picture below shows the bearing with a retainer bushing (prob not the right term) to keep everything locked in place. Sorry I don't have a better picture. IMG_0169.JPG
