Technical again, a litlle help here
Discussion in 'The Hokey Ass Message Board' started by leesnap, Mar 22, 2014.
  1. leesnap
    leesnap
    from boston
    Hey folks,
    I need a little help with wheel sizing...I think I'm over-thinking it....not funny right?
    Anyway, I have a 62 t bird and would like to put skinny whites on with supremes. I have the whites in mint condition,(205-75-14's) and the rims I have on are 14x5" x 5 bolt pattern x3.5 backspace. Now, the only closest rims that I found are 14x6" x 5 bolt pattern by 3.75 backspace. My question is will that rim fit my tire? And should I be concerned with the backspace with the wider rim? and....there is the same rim for sale just with less of a backspace (2.75"). Is that the right one? Sorry for confusion but I **** at numbers. Any help appreciated. Thanks,
    Lee
  2. Gerry Moe
    Gerry Moe
    14X6/3.75 backset will work fine with those wheels. 5-7" is the recommended wheel size for that size tire
  3. The wheel has 2 sides
    Your back space is 1/4 " less than the new wheel you are looking at- the new wheel will ride 1/4" closer on the inside as a result (towards center of car)
    Your current wheel is 1" narrower than the new one you are looking at - factoring in the 1/4" more backspace, the new wheel will ride 3/4" closer to the wheel lips (away from center of car)
    Total 1" wider
  4. bgaro
    bgaro
    i think your ok.
  5. Squablow
    Squablow
    '62 T-bird has a 4.5" pattern, not a 5", correct? I think you have the wrong bolt pattern.
  6. leesnap
    leesnap
    from boston
  7. leesnap
    leesnap
    from boston
    I just checked, you are right squablow and thank you-
