Age old turn signal mystery solved!
Discussion in 'The Hokey Ass Message Board' started by Idahorocks, Dec 2, 2013.
  1. Idahorocks
    Idahorocks
    from Spring, TX
    I've always noticed at the stop light in the turn lane that no two car's turn signals flash at the same rate. If they ever came close to matching I thought the driver might be a kindred spirit. But they never do sync up and I never understood why, especially if it was the same year, make and model car.
    Well, yesterday I was working on wiring my turn signals on my 34 Plymouth. I got the hazards flashing but couldn't get the turn signals to flash. My Hot Rod Wires fuse block has a dedicated two prong flasher for the hazards and the turn signal. Even when I swapped the flashers the hazards would flash and turn signals in the front and back would only dimly glow. I left the garage frustrated to give me some time to soak on the problem. I actually had a hard time sleeping last night because of it.
    Then around 2am it occurred to me that the rear tail lights are LEDs. They don't have nearly the same load as a filament bulb. So the hazards had just enough load from the front turn signals to work but a single filament bulb and LED load wasn't enough. And that's when it occurred to me that a typical flasher operates based on the load which is going to be unique enough that no two cars will every really flash at the same rate.
    So I think I solved the problem on my 34 but watching turn signals at the stop lights has lost its mystery.
  2. squirrel
    Yeah, understanding how the flasher thing works is helpful. There's a bimetal strip that heats up because of the current flowing thru it, as it gets to a certain temperature, it bends the contacts away from each other, breaking the circuit, and causing the lights to go off...as it cools, it then bends back and makes contact again, and starts heating up.
    http://www.howstuffworks.com/turn-signal2.htm
    Newer cars use electronic flashers, which have a timer circuit. And some very new cars are computer controlled, there is software that uses some type of time delay to run the turn signals.
  3. rusty1
    rusty1
    ...and I thot I was the only one who watched turn signals at stop lite!
    (maybe WE are kindred spirits)
  4. el Scotto
    el Scotto
    from Tracy, CA
    What's a turn signal?
  5. k1w1rodder
    k1w1rodder
    I just wave my arm up n down a bit faster:D in time
  6. squirrel
    I did the arm wave thing today, too. Then I found the blown fuse, and replaced it.
  7. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    That long thing that hangs off the left side of your body from the shoulder.
  8. 1971BB427
    1971BB427
    from Oregon
    Does that mean the new LED lights WILL all flash in unison?
  9. squirrel
    Try two new cars same make/model and see if they flash at the same rate. I dont' really care, but I expect they would.
  10. Model T1
    Model T1
    I may be old but when I sit in traffic I try to watch pretty girls in short skirts walking. Especially if they are braless. And most people in Florida either don't use turn signals or leave them on all the time.
    But then again, no two girls ****ies bounce at the same exact rate. So now I will lay awake tonight trying to figure this one out. I suppose determining whether or not those ****s are real or enhanced might make a difference. :confused:Yet another mystery of life. :)
  11. 1955IHC
    1955IHC
    ^^^ ModelT1 you make Florida sound so joyous. Here it's guess what's under the sweater weather.:D
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
  12. 3wLarry
    3wLarry
    from Owasso, Ok
    Ryan...Denny is off his meds again...
    kidcampbell71 likes this.
  13. Another age old mystery !!!
    Brother me and you are kindred spirits for sure
  14. Fopelaez
    Fopelaez
    Me too thought I was the only guy in the world who cared about how fast other flashers go. I always try to see if two cars flash at the same rate...:eek:
  15. Saxman
    Saxman
    Me too. I guess it gives me something to do while I'm sitting at the light and there are no ****ies to watch.
  16. Idahorocks
    Idahorocks
    from Spring, TX
    My wife is too quick to notice the smile on my face when I watch the ****ies.
    I installed an electro mechanical flasher tonight and it worked like a charm!
  17. Rickybop
    Rickybop
    I remember in 6th grade, watching the girls swinging on the school swingset.
    I noticed that Laura Murish and Susan Dunn never stayed in perfect sync.
    And I didn't really care either.
    Not much in the way of ****ies, but on the forward swing, there was often some flashing.
  18. LOST ANGEL
    LOST ANGEL
    I like watching posts on the HAMB as they start on one topic, then turn into something totally , mind bogglingly, weird!! Too freakin' cool.-MIKE:D:p
    PS-Every time I try to watch turn signals, I get hypnotized, and all I hear is horns blowing and people shouting to get my *** the **** out of the way!
  19. chevy57dude
    chevy57dude
    Turn signals are overrated. It's none of their damn business where I'm going. Eff 'em!
  20. blowby
    blowby
    from Nicasio Ca
    Don't most cars built in the last half decade have their lights controlled by computer and not us a conventional flasher?
    Personally, I'd like those old indicator arms that swing out from the A pillar. What did those come on, foreign cars?
  21. squirrel
    Semaphores. Common in Europe.
  22. Babyearl
    Babyearl
    Jim,, sounds like that would be hard to clean off the seats,, :eek:
  23. PackardV8
    PackardV8
    "Trafficators" were used on some '20s cars here in the US. More than you ever wanted to know:
    jack vines
  24. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    I got to vote with Model T1, I'd much rather watch the girls than turn signals. Maybe if the chicks had flashing lights on their ****s and ***es it would interest me!!
  25. Mike51Merc
    Mike51Merc
    Haven't you ever noticed that when you have a bad turn signal bulb that the remaining bulb flashes twice as fast? That's your warning signal to change the dead bulb.
  26. blowby
    blowby
    from Nicasio Ca
    Thanks! Those would be pretty neat tucked up under my model A visor. Sorry to stray off topic. Was there a topic?
  27. You must be hanging out in the wrong places!!! :D
  28. Olderchild
    Olderchild
    from Ohio
    I agree with you 57dude, no one to the right, no one to the left on a dead end street just that ***hole two blocks behind me WELL that ***hole was a cop:eek: that was a fifty dollar bill
  29. Rickybop
    Rickybop
    More commonly known as "whataretheyphors".
