air bag question
Discussion in 'The Hokey Ass Message Board' started by bdotson, Mar 7, 2012.
  1. bdotson
    bdotson
    from texas
    Question for all you air bag guys. I just bought an old 261 engine it has a air compressor mounted on it. Is this something someone could use for air bags? I dont need it if this is something someone can use I will list it in the sale area just wondering. I have all the brackets to fit a 235 chevy? thanks for you advice Buddy
  2. fastcar1953
    fastcar1953
  3. bdotson
    bdotson
    from texas
    yea try this [​IMG]
  4. 48 Chubby
    48 Chubby
    If the compressor is in good shape it will serve as an on board air compressor for a bag system.
    When I first read the thread ***le, I thought this was about air bags that pop out of the steering wheel.
  5. RAVENS29
    RAVENS29
    from n/a
    its really a compressor, thats wild!
  6. sobpunx
    sobpunx
    My 54 came with a on board compressor, look up york ac compressor conversion, I remember there was a good video on you tube about it
  7. ruralrod
    ruralrod
    boat anchor.
  8. hinklejd
    hinklejd
    from Fort Worth
    If you plan on using it for airbags, there are a couple things I'd do to extend the life of the compressor and increase the safety of your air suspension system. First, put some type of a clutch on the compressor so that it doesn't run all the time, similar to an A/C compressor. Run your air line through a check valve to an air tank, and use an electric switch with an unloader valve to actuate the compressor clutch. The switch should be set to disengage the clutch when the tank is less than it's maximum operating pressure. The unloader valve will release the pressure in the main line between the compressor and tank to keep pressurized air from 'sitting' on the outlet of the compressor head.
  9. Dane
    Dane
    from Soquel, CA
    Run the output into the top of the carb. :D
  10. squirrel
    be fun to get the hood to close over that in a car....
    Also it probably has a damper with some extra grooves, so it'd be fun to try to fit it in a car at all.
