air bagging a '53 merc?
Discussion in 'The Hokey Ass Message Board' started by oldskoolshop, Oct 10, 2012.
  1. oldskoolshop
    oldskoolshop
    anyone ever air bagged a '53 merc? what is involved? currently car has 3" dropped fat man spindles, 3" lowering blocks, had to removed 1/2 of the rear lowering blocks because drive shaft occasionally hit bottom side of tunnel by rear pumpkin!
  2. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    call me i can help 408 561 5744
    thanxs
    alex
  3. Simple you put in the late model colum of your choice and then you have an airbag.
    I suppose you could even have a p***enger side air bag if you rob the stuff from a real late model dash board. :rolleyes:
  4. You could also put a fat broad in the p***enger seat.
    Oh, that would be a wind bag! :rolleyes:
  5. Raise the tunnel and the problem is solved.
  6. Unless she has narcoplexy then she would be a sleeping bag. :rolleyes:
    Oldschoolshop,
    If your drive shaft is hitting the tunnel the simplest solution is to raise the tunnel, or make a hole in the tunnel where it hits.
    If you want to bag it then bag it but your question is like a fella saying my engine has lots of blowby where do I buy the best wide whites. You don't need an excuse to bag one if that is what you want to do. Just contact Gambino and be done with it.
