Technical Air brush for beginers
Discussion in 'The Hokey Ass Message Board' started by upspirate, Dec 21, 2016.
  1. upspirate
    upspirate
    I'm buying an air brush for my wife for Christmas, and wondered if this one will be OK for learning on and move up to a better one after we see if she likes it.
    I bought this compressor, and wondered about this brush:
    http://www.harborfreight.com/16-hp-58-psi-oilless-airbrush-compressor-60329.html
    http://www.harborfreight.com/deluxe-airbrush-kit-95810.html
    I realize there are better ones out there,but wondered if this would be OK to start and move up if she takes to it.(I think she will, she does lots of crafts)
    Not really sure what she would do with it, but I'm pretty sure she'll get into it
    Also, what would be a good one to move up to ( don't really need a $500 pro model though)
  2. HOTRODPRIMER
    HOTRODPRIMER
  3. HOTRODPRIMER
    HOTRODPRIMER
    upspirate and Murphy32 like this.
  4. Hi-Flying
    Hi-Flying
  5. clunker
    clunker
    from Boston MA
    I'm a big fan of Harbor Freight. But I would go with HRP this time. I was an illustration major in College in the 80's, a Badger 100 is what I used,
    and they aren't all that much scratch. Since Xmas is right around the corner maybe give her the HF to just play with over the weekend, and have a Paasche delivered next week. She'll find a use for it, like having two different colts going at once or something.
    This Badger 150 double action is a good one too (around $100)
    http://www.****blick.com/products/b...w=25002-0000&gclid=CJLv6_nChtECFYWNswod5MYEug IMG_1482365932.014695.jpg that is my badger
    The Paasche HRP suggested is just as good
    upspirate and loudbang like this.
  6. Slopok
    Slopok
    Harbor Freight will take it back with the receipt, even they know that they sell junk!
    clem and upspirate like this.
  7. metalman
    metalman
    I use to teach airbrush cl***es and I always warned my students to NOT by a cheap airbrush. Like HRP said above, start with a junk airbrush and you would probably give up out of frustration before you even had a chance. The old idea start cheap and upgrade later really doesn't apply with air brushes. They are a finicky little tool, very close fitting small parts. Of course price equals quality, you would be amazed at how better and easier a $400 airbrush sprays compared to a $100 brush. Now I'm not saying she should start with a $400 brush but seriously you probably need at least one in the $75 to $100 range, make sure it's a duel action. The Paasche HRP shows is a good brush, I personally like and use Iwatas and they too have good brushes in any price range.
    Of course I guess I should ask, what is she going to use it for? Lot of difference between needs for fine detail art to T shirts or cake decorating.
  8. JOECOOL
    JOECOOL
    The hock shops around here seem to have them quite often.
  9. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I like Iwata, you can pick up a NEO for under 100 pretty easy, or you can drop 300 on an eclipse.
    Whaever you get her get a dual action, big help for any sort of work.
    As for the HF tool glen weisgerber is a big time pro at paint work and he uses the HF unit. Did a few videos on them even, said its a legit piece.
    clunker and loudbang like this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Ideally you need to find out who has extra tip and needles,bend the needle and it won't work.
    I rebuilt the P***ache air brushes last week and one was made in the 70's. HRP
  11. Dean Lowe
    Dean Lowe
    If she is serious about airbrushing, do her a favor and get her a dual action brush. I have been using an airbrush to paint and weather large scale model trains for almost 30 years. I use, and highly recommend the Badger line of brushes. A single action brush is just as hard to learn, and much, much harder to get the results you want.
  12. Ebbsspeed
    Ebbsspeed
    Can one of you point out the difference between a single and dual action airbrush? Thanks in advance.
    belair likes this.
  13. Russ B
    Russ B
    I have a few air brushes, all dual action. The only one I really use is my Iwata HPC ( I think that is the model name). I just use my shop air, about ninety feet from the compressor, pressure regulated, dropout, and TP type filter/dryer. Iwata is great quality, in my opinion.
  14. belair
    belair
    I second the request for an explanation of single and dual (a duel is a fight) action brushes.
  15. David Gersic
    David Gersic
    from DeKalb, IL
    Single action = you control only airflow. Air ****s paint through a fixed orifice, and sprays it on whatever you're pointing it at. Works like a carburetor basically. You can open or close the ****erflies (airflow). The Venturi affect pulls gas through.
    Dual action = you control both airflow and paint flow. Air ****s paint through a variable orifice. Imagine a carburetor with infinitely variable jets.
    clunker and belair like this.
  16. Ebbsspeed
    Ebbsspeed
    Thanks! So dual action is similar to a carbureted airplane piston engine, where you can adjust both the throttle and the mixture from the ****pit. Makes sense.
  17. upspirate
    upspirate
    Thanks for all the opinions/advice . I knew the HAMBSTER family would come through!
    As far as the usage, who knows what she will do with it, but she will probably use it for painting pics as she does that now, ( watercolor,oils,s-pen on a tablet,pencil drawing, etc) ceramic decorating, NO cake decorating as she does lo-carb, and I don't eat cake. I thought about one of the small blasters for etching gl*** etc to go with it also.....I do some stained gl*** every so often and it would be nice to have a way to etch designs on some of my pieces.
    I decided to wrap the compressor I already bought, not open the box and return it to H-F after Christmas as the set I just ordered won't be here in time.
    I just ordered the compressor / brush set that HRP suggested. Thanks again all
    clunker and jnaki like this.
  18. HOTRODPRIMER
    HOTRODPRIMER
    The double action air brush works very similar to a conventional automotive spray gun just considerably smaller.
    The advantage to a lot of the dual action brushs like a Paasche is the ease in which you can change out the head ***embles and needles that comes in a 1,3 or 5 and these control the paint from a hairline up to a wider pattern. HRP
  19. ClayMart
    ClayMart
    If she's never used an airbrush before I'd lean toward the Paasche model H single action brush. It can handle a decent variety of media and in this kit it comes with three different sizes of nozzles and aircaps for fairly fine to broader spray patterns. It's easy to clean, stone-axe simple and less prone to damage. If she gets a feel for using this then the Paasche V dual action brush would be a nice upgrade. And the H will still be useful for other specific tasks.
    https://jet.com/product/detail/7d37...61_kwd-4579122332323962:na:na:na:2&code=PLA15
  20. Jalopy Joker
    Jalopy Joker
    so, what is it that you want painted with a air brush? has she ever expressed interest in air brushing?
  21. upspirate
    upspirate
    She's just interested in trying new things.For example I bought her a cheap Dremal style tool and attachments & she loved it so I upgraded to a much better one.
    I think she'll get into the airbrush and who knows what different things she'll use it for !!!
    clunker likes this.
  22. henryj1951
    henryj1951
    from USA
    dual is paint
    and
    air , so you can use only air when you want
    here's a vid on 70's
    WITH airbrush freak dots being made
  23. clunker
    clunker
    from Boston MA
    It's a great gift idea, she's gonna love it
  24. 56 Dodge Pickup
    56 Dodge Pickup
    Oh yeah please don't forget to post some of the art work on the Friday Art Show threads so we can all enjoy them Merry Christmas!! Hobo Jim
    upspirate likes this.
  25. upspirate
    upspirate
    Well , she's very excited about getting into this art-form. You should have seen her face when I said you can unwrap the H-F compressor, but not open it and we are taking it back Monday!!!
    I showed her the link HRP sent and I ordered from.
    I also got her one of those little eraser/ blaster things so she can etch, etc with it
    Thanks again for all the knowledge and help to get the right stuff
    clunker and David Gersic like this.
  26. xpletiv
    xpletiv
    from chiburbs
    Find a 40% off coupon from HobbyLobby and see if you can use it on their airbrush equip.,
    they have full kits and parts.
  27. No Plan
    No Plan
    Had Paasches since I was 13 years old. First was an F then a little later dual action VL's. I am now 66. A few years ago bought my first Iwata. Wow! IMHO it's the Cadillac of breeze brushes! Used it last week on a Christmas sign for my wife. Love it like no other.
    fullthrottle24, clunker and upspirate like this.
