Technical Air compressor help
Discussion in 'The Hokey Ass Message Board' started by johnfin, Dec 18, 2022.
  1. johnfin
    johnfin
    from Florida
    I have a 60 gallon craftsman twin that is leaking out of the small pipe that is under the pressure control and goes up to the head. Line is cool. It has some type of unusual plastic fitting that the metal pipe pushes into. How do I fix this thing?
  2. A picture is worth a thousand words .
    they have been using plastic tube and those “ shark bite” type fitting for air for a long time , might be those ?
    Not sure with out a pic
  3. omendeavors
    omendeavors
    check valve not holding
  4. A 2 B
    A 2 B
    from SW Ontario
    I often wondered about the longevity of a Sharkbite fitting used on plastic in a high vibration environment. They have a 50 year guarantee when used with copper water lines but air compressors are a different animal.
    I would find the customer service contact information of Craftsman and describe the condition to them. I've had success several times dealing directly with the manufacturers, where they send out the needed parts with no charge. It's good customer relations that keep them coming back even if out of warranty. Its not time sensitive if just a leak, so send out an email or make a phone call. Just a thought.
    Bill's Auto Works likes this.
  5. jimvette59
    jimvette59
    That looks like it has been bent. It is going in at a angle. Maybe try to straighten it out and push it in ? JMO
  6. johnfin
    johnfin
    from Florida
    I have never heard of those types of fittings, how do they work?
  7. King ford
    King ford
    from 08302
    “ shark bite” …..has an O ring to seal around the OD of a tube or pipe and and spring loaded teeth that kinda looks like an open shark mouth to keep the tube in …..just push together and you’re done!!..first one I saw I thought “ jury rig”….but they work well!
  8. larry k
    larry k
    Your submergeable check valve is sticking !!! take it out , clean it , put it back in …
  9. Distracted
    Distracted
    I just went through this myself. The one way check valve from the compressor pump to the tank is not sealing properly. This allows air in the tank to back up through the pump when it is idle and the air back flows to the pressure switch. You need to remove the one way check valve and clean it or replace it.
    Bill's Auto Works and ottoman like this.
  10. johnfin
    johnfin
    from Florida
    Ok, its not the shark fitting, its leaking up in the pressure regulator. I fiddled a bit with the adjustment and it still leaking. The part is riveted together so I guess I need a new one which will bring me back to the "shark bite" fitting. How will I get the tube out of that for a replacement.
      188.4 KB
      285.4 KB
  11. tommyd
    tommyd
    from South Indy
    For what it's worth the TSC Farm Stores in my area have regulators in stock.
  12. nochop
    nochop
    from norcal
    I’ve replaced faulty accoutrements with generic parts.
  13. johnfin
    johnfin
    from Florida
    so once I get the new regulator how to I get the hose loose from the shark bite?
  14. Budget36
    Budget36
    I’m not familiar with ones for steel tubing, but we have some in use at work for plastic, there’s a “ring/collar” on the fitting where the tubing slides in, push it in to release. Couldn’t make one out in your pic, got too blurry for me when I expanded it though.
  15. The ones I've seen are just like an air line fitting, you push in the metal tube, push in the br*** ring and while holding in the br*** ring you pull out the tube.
  16. ottoman
    ottoman
    from Wisconsin
    Make sure there is no air pressure in the system, lets the line release from the fitting easier!
  17. johnfin
    johnfin
    from Florida
    Well I replaced the regulator with the same brand part my craftsman compressor and while it worked for a while like a week, its back to leaking down to zero again in the same area: where the plastic piece goes up into the regulator. There is like a shaft up in there. Its NOT the pipe that leaking. What gives?
  18. Ebbsspeed
    Ebbsspeed
    Did you clean that check valve that several people mentioned?
  19. johnfin
    johnfin
    from Florida
    I saw that post about the check valve but i thought it was part of the regulator. Where is the check valve?
  20. omendeavors
    omendeavors
    The check valve is located in the tank at the end of the discharge tube
  21. omendeavors
    omendeavors
    Sorry make sure there isnt any pressure in the tank before you remove it
  22. johnfin
    johnfin
    from Florida
    When you say discharge tube do you mean the side of the tank where the air hose connects?
  23. omendeavors
    omendeavors
    the tube or pipe from compressor to tank
  24. omendeavors
    omendeavors
    the line that goes into the tank between the line and the tank
  25. johnfin
    johnfin
    from Florida
    I dont see any place a check valve can be.
  26. omendeavors
    omendeavors
    right below the tube going into the tank remove the tube then unscrew the valve out of the tank
  27. johnfin
    johnfin
    from Florida
    Thanks guys. Its out. A little ****** because of the side set screw. Its junked up. Are these available? Cant find the model number of my machine.
  28. rusty valley
    rusty valley
    Test for leaks with a spray bottle with soapy water in it
  29. omendeavors
    omendeavors
    some of them come apart its a spring and nylon disc
