air compressor
Discussion in 'The Hokey Ass Message Board' started by opu27, Jun 7, 2012.
  1. opu27
    opu27
    from ONYX,CALIF
    anybody have experence with harbor freight vertical air compressor looks like electric ?
    reg price 219.99. now on sale 149.99. 2.5 HP, 21 GAL,125 PSI. I am thinking of buying one. thanks, ****
  2. randyhobson
    randyhobson
  3. Mr48chev
    If you just want it so you have an air compressor to air up tires and blow things off and maybe use with an impact wrench once in a while it will damned well beat a poke in the eye with a sharp stick but little compressors won't keep up with a lot of air tools or sandblast equipment at all.
    I've got one of their little 8 gallon compressors that they sell for around 100 buck that does air up tires and lets me blow the dust off things but doesn't have enough poop to run my impact to break a lug nut loose on my pickup. Not fancy but it saves taking the air tank to town to fill it up to go home and air up a tire like I did for a lot of years.
  4. Black Primer
    Black Primer
    What MR48 said. Save your money, maybe find a larger used one. An air compressor is a tool to build your shop around, get a bigger one.
  5. carcrazyjohn
    carcrazyjohn
    from trevose pa
    or around 500 or 600 you can get a bigger one.Dont waste your money.Go big the first time.Like a black max is sufficient....
  6. tubman
    tubman
    If you've got 220 in the shop, get a 220 aircompressor.
  7. FamousVir
    FamousVir
    from Malawi
    I'm surprized, thanks!
  8. mustang6147
    mustang6147
    from Kent, Ohio
    I would get the Harbor one, and opt for the warranty... Print 20% off coupon, that will cover the 2 year warranty...
    They stack coupons over by me...
