Projects Air Filter Replacement
Discussion in 'The Hokey Ass Message Board' started by Ima, Aug 17, 2023.
  1. Ima
    Ima
    from New Englnd
    OK I admit I'm no mechanic, but I been around old cars for a long time. Bought a 54 Mainline 8 months or so ago and recently saw some black smoke on startup, so time to check the air filter. Surprise, the housing does not open/it is 1 solid piece with the air filter inside. I've never seen that before it this common on vintage 50 cars?
  2. 302GMC
    302GMC
    from Idaho
    It opens ... it's packed full of a mixture of dirt & oil that flowed over the flange on the bottom of the element.
  3. Ima
    Ima
    from New Englnd
    302 That's what I thought at first but the top was actually bend under the lip of the bottom part of the housing. I had to unbend it to remove. That has never been opened in 60 odd years from the looks of the filter. It's some kinda fiber, not the paper filter we have now. I assume was meant to last forever! Got it opened now gotta go buy a new top cover lol.
  4. Budget36
    Budget36
    Can you put up a few pics of it?
    Has me curious.
  5. Paul
    Paul
    Editor
    oil bath air cleaner?
    undo the clamp holding the outer housing on the carburetor
    and any bracing from air cleaner to engine
    set the whole unit on the bench
    remove the wing nut on top
    lift the whole lidded inner housing out and wash with solvent.
    it is not meant to come apart.
    wash the outer housing out.
    put it all back together in reverse order
    add fresh motor oil filled to full line on the inside before installing the inner housing
    Bandit Billy and Moriarity like this.
  6. Budget36
    Budget36
    That’s why I asked for a pic of it. :)
  7. miker98038
    miker98038
    Make that 2 of us. I’ve only seen the oil baths, or ones converted to paper.
  8. Paul
    Paul
    Editor
    the oil bath air cleaners work quite well in stock applications
    probably better than any paper filter
    they are quiet, filter well and when clean flow well too.
    Oneball likes this.
  9. Bandit Billy
    Bandit Billy
    I just cut up an Desoto old oil bath, it was an educational experience to see how and why it was made and used. It is also a filthy, stinky job to open up an 80 year old, oil soaked filter. I converted mine to a paper element.
  10. Ima
    Ima
    from New Englnd
    Yes Bandit that's exactly what mine looks like; the cover then the screen then the oil soaked filter. I too will be converting to a removable paper element
    Bandit Billy likes this.
  11. Bandit Billy
    Bandit Billy
    If you like I can post what I did to convert mine.
