air ride question
Discussion in 'The Hokey Ass Message Board' started by sandimasguy, May 23, 2006.
  1. holliwood
    holliwood
    Actually, a lot of people use only 4 valves, but they usually use sway bars too to keep from leaning. But, you are right; individual valves for each front side are definitely better and will eliminate the roll. You don't necessarily need individual rears, but that's your choice.
  2. AccuAir
    AccuAir
    Lean is definitely an issue with a 2-way setup... This guy had resorted to elevator weights under his running board on the p***enger side just so it would sit level :) That only worked of course until a p***enger got in. He's definitely a believer in a 4-way system now!
