Air Sunspension Help.
Discussion in 'The Hokey Ass Message Board' started by 58 cadisled, Jul 17, 2010.
  1. 58 cadisled
    58 cadisled
    from Duncan, OK
    Hey fellas i'm looking to put an air ride suspension on my 58 cadillac. I need some help, so any suggestions, advice, or comments are much needed!
    Thanks Cody.
  2. FrozenMerc
    FrozenMerc
    Try the search button. There is a ton of threads on here covering this subject in every way imaginable.
  3. hombres ruin
    hombres ruin
    Research the crap out of it.There are so many things that can go wrong with air suspension,in my opinion you must plan each detail out,from the parts you are going to use, to who is going to install it,how good are they,what are their welding skills like and how many bag jobs they have done.They need to be good with angles as well.Once you get that out of the way,its worth it,bagged cars lay nice.Good luck
  4. Ace50coupe
    Ace50coupe
    from Indiana
    air ride tech would probably know about that just look them up. They are based out of Indiana.
  5. TMoney
    TMoney
    There are a few guys on here that are really good with bags. Do a search and you will find them posted on many threads. Good luck.
  6. shoot me a PM when your ready for parts, we are the cheapest around!
  7. Hey Cody,
    Since air ride was an option offered on 58 Cadillacs from the factory, the frame and control arms are likely roomy enough to add air ride without too much cutting.
    You might want to give these articles a good look over. They pretty much tell you what to do.
    FRONT:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    http://www.webrodder.com/article.php?AID=217&SID=1<o:p></o:p>
    <o:p></o:p>
    <o:p></o:p>
    If it were me, instead of the "Shock Wave Air ride", <o:p></o:p>I would save a lot of money and use regular air bags with standard tube shocks mounted separately to the frame, the same way Cadillac did the 58 on the air ride cars.
    Hope this helps,
    Greg
  8. There are some pictures of air ride Cadillac frames here:<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:eek:ffice:eek:ffice" /><o:p></o:p>
    <o:p></o:p>
    http://forum.classic-cadillac.com/g...ile=index&name=gallery&include=view_photo.php<o:p></o:p>
    <o:p></o:p>
    You will have to search, I know there are pictures showing the frame parts, but I'm not sure exactly where.... It's been a few years since I surfed here.<o:p></o:p>
    Later,
    Greg
  9. 58 cadisled
    58 cadisled
    from Duncan, OK
    Thanks guys for all the help. Cody
  10. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    give us a call we'll get pointed in the right direction
    408 561 5744
    thanxs
    alex
  11. Lots of knowlegable people here just ask questions. I used shockwaves up front and air over leaf out back. Give Alex a call
