Projects Airbags on my 1957 F100 (Build Thread) Finally!
Discussion in 'The Hokey Ass Message Board' started by custom100, Dec 13, 2010.
  1. rockher_man
    rockher_man
    Custom100...KOOL fab work!
    Well...this thread did it for me!.....:D...
    I've been talkin' to Reno about this system since early 2009 and after
    reading thru this thread...I picked up the phone and ordered everything I
    needed for our '56 Effie....
    NOW I gotta get my *** is gear,... TCI MII IFS...No Limit Engineering
    Fat Bar 4-Bar out back all on Firestone bags...
    For the "notch" I picked up these pieces from Art Morrison to simplyfy things
    just a little 'cause they are the same size as the rails...you can
    order them bent either way...mine are mandrel bent the "the hard way"
    as it says in the catalog...:D...
    http://www.artmorrison.com/2006cat/27.pdf
    Now I finnally got the BEST system to make it all work correctly...
    Oh boy is my wife happy...:eek:...when I get my act together I'll start
    putting together a build thread....
  2. billylo
    billylo
    I love the 57's.....You really did this one justious......Sweet!!
  3. iwanaflattie
    iwanaflattie
    wow what set of skills super clean even the floor was clean.
    I gotta get outta gravel
  4. DE79
    DE79
    from Austin,Tx
    Great choice,I really like Accuair's valve and controls.
  5. ratrodross
    ratrodross
    from UK
  6. rockher_man
    rockher_man
    Did you mount the REAR sensors to the lower bar OR the upper
    on the 4-bar setup?....:confused:...
    Looks like the upper...just wanted to make sure since yours came out so
    kool...THAT is a great idea....thanks man...REALLY nice work...
    What size air tank are you using?....1 or 2 compressors?.....
    I picked up the VIAIR 400C Dual Performance Value Pack and
    a 12-gallon tank BEFORE I sort of knew what I was doin'...now
    I think I need to get a smaller tank...
    Thanks...sweet truck....howZ it doing.....
  7. custom100
    custom100
    Hey Rockher_Man, I attached them to the upper bars yeah. It worked out great because you could only see them if you laid on the ground.
    The airbags on that truck made it fun to drive again! With as simple as the e-Level is I could even let my wife drive it without worrying about her putting it at the right height.
    Yeah, I'm talking about the truck in past tense because I sold it. I drove it and had a lot of fun with it, but I can't go to long without building something new so it had to go to fund the next one.
  8. tattedfordguy
    tattedfordguy
  9. dullchrome
    dullchrome
    from SoCal
    Great truck, I remember it at last years GNRS. Were did it end up?
  10. rockher_man
    rockher_man
    SWEET!....thats what we are hopin' for...:cool:...
    I ordered the Stage II kit minus the tank & compressors 'cause I
    already had those....****....like I said....this was before I did ALL
    my homework and bought a damn 12-gallon tank!!!!
    I was just wondering what size tank YOU used?....I think this TWELVE
    gallon thing is gonna be TOO big....even with twin 400C compressors!....
    Thanks again....too bad it had to go....now you can get started on the
    next one....
  11. custom100
    custom100
    rockher_man,
    Yeah, in my opinion the 12 gallon tank is too much. I had (2) 3 gallon tanks on my truck and it worked great. The thing that most people don't get about an air tank that big is it takes more then twice as long to build the pressure high enough to lift the truck. With my 6 gallons of tank volume the (2) 400C's would fill from 110 to 150 psi in about 50 seconds. it would take at least 2 minutes to get your 12 gallon tank back to 150.
    Also not sure if you got an aluminum tank but steal tanks often cause issues with rust and debris because of the corrosion from the water that will get into them. I always use aluminum tanks on my airbagged vehicles.
    Hope that helps you get it figured out. If you run into anything else feel free to ask and I'll answer anything I can.
    haps79 likes this.
  12. gilles d
    gilles d
    from winnipeg
    very nice truck,cool color
  13. 60EFFIE
    60EFFIE
    Was anyone able to determine the color of custom100's truck?
