aircraft speed sensor used as auto speedometer
Discussion in 'The Hokey Ass Message Board' started by luckyfasteddie, Jul 18, 2009.
  1. Flat Ernie
    Flat Ernie
    Tech Editor
  2. HOT ROD DAVE
    HOT ROD DAVE
    i would agree it will be off a couple mph, but hay it sounds great to ya so go for it
  3. milwscruffy
    milwscruffy
    Yes as a matter of fact. VW engines were modified and used in plenty of planes in the past.
  4. Fwiw - it's called Airspeed Indicator.
    The pitot is the dynamic/pressure air device.
    The airspeed indicator requires a source of static air as well.
    You can see the static air pickup on the left side of most Cessna aircraft.
    In some flight configurations the static air pickup will be exposed to more or less pressure depending on which way the airplane is traveling.
    IE: in a slip to the right or the left.
    These differing pressures make the airspeed indicator inaccurate to a small extent.
    Which means that crosswinds, headwinds and tailwinds will add to the inaccuracy factor with the instrument installed in a car.
    Even so, it looks like a cool device to install in a hot rod.
    As is an altimeter.
    Better than an altimeter may be the VSI (Vertical Speed Indicator), you can see climbs and descents in the hills easily although you can do the same with a common automobile vacuum gauge.
    Since we're talking about cars with interesting instruments, I'd like to see a small altimeter as well as ambient air temp gauge with remote sender that matched S-W's in both size and appearance.
  5. Please, post pics when done. If nothing else will be a good conversation piece (not that Lucky Fast Eddie needs that. )
  6. luckyfasteddie
    luckyfasteddie
    Well it's been in use now for almost a year and seems to be working pretty good. Most people don't reconise the tube on the hood and think it's a tach on the dash .Airplane guys seem to like it.
      401.5 KB
      250.3 KB
      251 KB
      424.9 KB
  7. MEDDLER1
    MEDDLER1
    Wierd I just saw this the other day on hot rod tv.Troy ladd put one on the platinum bomb roadster.Very cool idea!
