Airheart brakes
Discussion in 'The Hokey Ass Message Board' started by Hyde_Auto_Body, Sep 4, 2013.
  1. Hyde_Auto_Body
    Hyde_Auto_Body
    Does anyone know where to find rotors for an Airheart disc brake set up for Olds/Pontiac rear end?? My rotors need replacing soon.
  2. brandon
    brandon
    speedway or strange, wildwood, or aerospace.
  3. dreracecar
    dreracecar
    from so-cal
    The only way to get new rotors for the Airhearts is to make them yourself or have them made. While not difficult it gets pricey because they have to be blanchard ground to thickness and you are only doing 2. To have them made you would be at over half the cost of buying a complete new braking system from Willwood and a better system. Offset the cost buy selling the Airhearts to restoration people, since this is from a working car, the calipers are in good shape.
    PM me if you still want them made.
  4. brandon
    brandon
    post a pic of what you have....
  5. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    8 on 7 and 7-5/8 is a common solid rotor bolt pattern for Wilwood and A/H so you might find a Wilwood rotor that will work.
  6. rooman
    rooman
  7. You may try airheart. They have a web site.
  8. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    upgrade
    aerospace components "look" trick
  9. Boones
    Boones
    from Kent, Wa
    1. Northwest HAMBers
    My dad has them on his gasser with an Olds rear. He went back to Airheart to get some parts (just a few yrs ago)
    before restoration
  10. brandon
    brandon
    Are the hats on the inside of axle flange or over it...? Worse case get a hat and rotor that has same offset....check speedway in the dirt track and sprint car stuff....
  11. 40FordGuy
    40FordGuy
    I'm with going to a new system, which would mean readily (less expensive) available parts.
    4TTRUK
  12. Shaggy
    Shaggy
    from Sultan, WA
    Rears are easy, anything will fit, just remachine it to go on there!!!
  13. Hyde_Auto_Body
    Hyde_Auto_Body
    The brakes actually are working quite well. I'd really like to keep the set up on the car since it still has a lot of the vintage parts from the 70's still on it. One of the rotors has some scoring but they are still thick and maybe I'll see if it will clean up with turning it. I also want to rebuild the Hurst master, get new pads and rebuild the calipers but I do see parts to rebuild them online so going through the master and the calipers should be easy.
  14. Hyde_Auto_Body
    Hyde_Auto_Body
    Yeah it looks like if your still interested in making a set of these for my altered I'll have you do it. When I put the car away for the season I'd like to go forward with it.
  15. dreracecar
    dreracecar
    from so-cal
    Call me when you are ready
    1-310-768-3163
