alignment questions
Discussion in 'The Hokey Ass Message Board' started by lorodz, Apr 10, 2011.
  1. lorodz
    lorodz
    ok so i have a couple questions about the alignmet on my roadster
    im using a 5 or 6 inch taffy pulled axle, 40's spindles dropped steering arms from pete & jakes and a f1 steering box everything is installed nice and clean, tight with no play other than what is needed. now i took the car for a small drive and noticed that when the steering wheel is center in the car and im rolling at a speed above id say 15 mph the car pulls left right left right now i noticed the car did this before i swapped to dropped steering arms so maybe the alignment is off does anyone have a diagram on how the wheels should be kicked when driving straight i have them kicked in towwards the grille where is a basic starting point to get a close to perfect alignment..so i have controll at the wheel.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    When you say kicked out do you mean caster. Meaning like looking at the forks on a bicycle from the side.
  3. lorodz
    lorodz
    not caster,not camber .maybe its called toe
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ok, do have any idea how much toe it has now.
  5. Mr48chev
    I'm having trouble deciphering what you are actually saying just as Johnny Gee seems to be.
    Caster should be about 7 degrees positive or like the rake on a bicycle fork. Who ever dropped the axle should have set the camber so that shouldn't be a real issue but I usually like a quarter of a degree more positive camber on the left wheel than the right wheel.
    Toe in should be set at 1/8 inch to start.
    The most accurate way I have found to set the toe in on a car or truck by hand at home is to jack each wheel up and using something to steady your hand make a mark on the center of the tread with a pencil while you rotate the tire. When you have the mark on both tires let the car down and measure from mark to mark front and back and figure out what you have. hopefully you end up with 1/8" less on the front side than the back side. Using the pencil to place the mark on the tread and measuring from mark to mark compensates for any tread or wheel runout you might have and gives and accurate reading.
    Measure at the same height from the floor front an back when you do this.
  6. lorodz
    lorodz
    yea im guessing its the toe
    i was trying to figure it out today but im lost when it comes to this someone told me the front side of the wheels should be facing outwards is this tru
  7. lorodz
    lorodz
    no i dont this is why im posting just trying ot figure out how to get a base to go off of
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    So you mean as if you was looking down on car from a ladder or roof or airplane LOL.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Like 48 said 1/8 toe in. That means front is narrower than the back when you messure.
  10. lorodz
    lorodz
    ok so let me get this straight i mark the center of each wheel all the way around than measure the center line in the rear of the tire than measure the center line in the front of the tires across and kick the tires in 1/8th of a inch in front ?
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Winner Winner Chicken Dinner, you got it.
  12. lorodz
    lorodz
    i was about to try that today and thought i was gonna mess somthing up so i left it alone till i got some info .... will the toe affect the steering that much ..its a scary ride when the car wants to go in both directions at once
  13. F&J
    F&J
    Toe out causes the car to wander all over and jump lanes if it's real bad.
  14. lorodz
    lorodz
    thats what its doing wandering like a damn drunking sailor ..i have very little control of it i thought it was the steering box so i adjusted the **** out of it ,than i thought it was the steering arms just replaced them so its gotta be something in the alignment .
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Im no front end expert and get by on my own well. Also, I've only messed with A-frame stuff. Although the same applies I would look at the caster myself.
  16. lorodz
    lorodz
    what should the caster be set at ill check that to i have a angle finder to help me so im sure i can figure it out
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Mr48chev posted 7* on reply #5
  18. roundvalley
    roundvalley
    Caster is a good check but lets back up one step. Have you measured from the center of the front hub to the center of the back hub on each side of the car to make sure they are equal distance and square?
  19. lorodz
    lorodz
    nothing is measured yet.thats was my next question is there a base to start at a formula from a to z to get me were i need to be
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Good point. But to get a square measurement you need to also measure in an X manner as well. I prefer a 3 point measurement to get things squared up from a good center point. Lorodz do your toe and caster first and go from there.
  21. JonF
    JonF
    Mr48Chev said " I usually like a quarter of a degree more positive camber on the left wheel than the right wheel. "
    Can ju 'splain how dat werks?
  22. lorodz
    lorodz
    why a 1/4 more camber ?
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If I remember correctly is to compensate for crown in the road. However this is set into axel and cannot be changed by simple adjustment. Note: thats a 1/4 of a degree
  24. lorodz
    lorodz
    well as far as i know the only thing i can check and change is the toe and the caster only thing is that i have split wish bones so i may have to pie cut and set the angle than re weld them ...
  25. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yep, will be watch'n to see what you come up with. Later
  26. 19Fordy
    19Fordy
    No! The wheels should point "in" toward each other.
  27. roundvalley
    roundvalley
    TOE IN not HEEL IN!
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    :eek: She looks a lil bow legged to me :D
  29. sdluck
    sdluck
    I believe the rs used to have more caster if possible then the Ls for road crown not camber
  30. ErikHardy
    ErikHardy
    Bump steer could also be causing some of your problems, ie toe out throughout travel. Toe settings have a drastic affect on steering and even the slightest mis-alignment can cause problems.
    I'm not a fan of drawing a mark down the center of the tire as I don't have that steady of hands. Find some plate that you know is flat and stand them up on the outside of the tires and measure from there. If you really want to get exact take the rim off and bolt the plates to your hub and measure.
