alignment specs for mustang II
Discussion in 'The Hokey Ass Message Board' started by pepeford50, Apr 2, 2007.
  1. pepeford50
    pepeford50
    does anybody have alignment specs for a mustang II front end
  2. J.D.
    J.D.
    from Clovis, CA
    my alignment guy just plugged a mustang in the computer when he did mine (came out perfect) don't know what year they started making them in. Might help?
  3. 1/2 degree camber on the left 1/8 degree on the right
    1 1/4 degree caster on the left 1 1/2 degree on the right
    zero toe with radial tires unless you are getting bump steer
  4. 1 1-2 degrees caster for non-power assist and 3 1/2 degrees for power assist steering.
  5. Jalopy Joker
    Jalopy Joker
    Are you running a stock or aftermarket Must II? If aftermarket check manufacturers site. Some kits have extra caster built in. Most hot rods handle better with more than 1 1/2 degree of caster.
