We have created this Table Lamp using carefully cleaned repurposed parts. The Base is a 3/8" steel plate with Valve Springs attached by Tig Weld. The Stem is a Sport Bike Crank Shaft. The Shade is an Oil Pan, with a painted black finish. The base and crank are Heat Blued and Clear Coated. Holds 2 light bulbs. Will need your zip code for shipping cost. contact innovativedesignspecialties@gmail.com
