all geared up
Discussion in 'The Hokey Ass Message Board' started by c.cwf, Dec 31, 2011.
  1. c.cwf
    c.cwf
    Im running a 1991 305.1977 350 turbo ****** and a 2001 chevy blazer rear axel. It's tackin roughly 4 grand at 50 mph.should I change the rear gears or should I get a 700 r .just don't know. Any ideas.
  2. el Scotto
    el Scotto
    from Tracy, CA
  3. mgtstumpy
    mgtstumpy
    ^^^^ Yes x 2. I run a 700R behind my 305 and with 3.5:1 rear end and 235:75:15 tyres it turns 2K rpm at 60mph.
  4. 38Chevy454
    38Chevy454
    You either have *very* low gears or you are not in high gear. Your linkage adjusted correctly? Even my old V8 Vega with 4.10 gears and no OD, with 14 inch wheels and tires in the stock wheelwells, would turn 3500 rpm at 55. To be turning 4000 at 50? You have something wrong, either your tach is messed up, or you have some strange non-factory rear gears in that S-10 rearend. I'm going to guess your S-10 rear should be around 3.73 gears if stock.
    A 700R4 is a good choice though.
  5. flamedabone
    flamedabone
    See if you can get better than "tackin roughly 4 grand" cause 3200 and 4000 might sound the same, but are actually waaay diffrent. Time your car between mile markers to get you at 60mph in 60 seconds then, look at the tach.
    Most Blazers come with a 3.73 or 4.11 rear and with a 28 inch tall tire you might see about 2700 with the 3.73 or 2900 with the 4.11 @60mph.
    Good luck, -Abone.
  6. c.cwf
    c.cwf
    The rear is from a 2001 4x4 blazer and no .I am 100% sure I am in third gear and you don't need to look at the tach you can listen and hear im taching high too high .thing is its a new ****** and the rear is welded for my setup I just thought the easier route may be changing the rear gears but I think they need to be shimmed in. I have no experience with that. It may be a cheaper way to fix this. Also my ****** is a long tail I would also have to get a new drivahaft if I changed the ******
  7. c.cwf
    c.cwf
    Happy new year
  8. Jalopy Joker
    Jalopy Joker
    search here for the ways to figure out what gear ratio you have. no expert but, there is a S10/Blazer 4:56 ratio - glove box code HC4. one option is to change out the complete rearend. also, do a search here and maybe online for info on the dimensions of a 350 and 700R4. you may be closer to a 700 than you think. there should be info here about upgrading. no matter what, you need to know the rear gear ratio. all of your options will take time, parts and $$. but, will cost more if you over rev your motor.
  9. drptop70ss
    drptop70ss
    from NY
    Lots of S10 rears came with 4:10s, believe it was stock with the 4cylinder 5 speed 2wd trucks. I have one of those rears in my buick and run a 700r4, works great.
  10. caseyscustoms
    caseyscustoms
    from st.joe, MO
    your an idiot... go away.
  11. Larry T
    Larry T
    Works out to around 6.50/1 gear ratio.
    Something isn't right.
    Larry T
    Bowling's Vehicle RPM Calculator
    Input Parameters Are the Following:
    Differential Gear = 6.50 to 1
    Transmission Gear = 1.00 to 1
    Tire Diameter (Inches) = 28.00
    Vechicle MPH = 50
    Computation Results:
    Computed Engine RPM is 3902
  12. Don's Hot Rods
    Don's Hot Rods
    from florida
    Larry's numbers are just what I came up with too. Something is really not right. There is no way you can be cranking 4000 at 50 mph unless you are running stump pulling gears. I am running 4;30's with no overdrive and I only tach 3000 at 60 mph.
    You either need a new tach or you are running lawn mower tires. :D Or, you started your New Years celebrating way too early.
    Don
  13. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I ran 3000 rpm at 60mph in my 4.10 geared Duster.
    Commenting on your God statement would go against HAMB policy, so I'll just say you're an idiot.
  14. c.cwf
    c.cwf
    Some people just love to be offended .but me im good with it all. Maybe im too laid back but hey different strokes for different folks.
    Any ways thanks to all for the info.
  15. gimpyshotrods
    gimpyshotrods
    This does not belong here. Please read and abide by forum rules.
  16. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    Im personally no fan of 700r's and would be easier to swap rear end gear... why tacking out at 4k?
  17. c.cwf
    c.cwf
    Red em. Feeling much better now.I can't believe im gonna do this but here goes. IT WAS A JOKE HA HA I TAKE IT BACK....there now let it go for the love of G@d oops.sorry
  18. gimpyshotrods
    gimpyshotrods
    Built properly, there is not a problem with the 700R4. Their bad reputation us undeserved.
    It can't be running at 4k. The math is not there. Larry T has demonstrated this. The tachometer is off, and the exhaust is just loud, or it is not in top gear.
    I have 6.50:1 gears in my A (which I will be changing to 6.00:1), and am running 30-1/2" tires. I am, or course, running a 0.50:1 top gear.
  19. c.cwf
    c.cwf
    Ok I ran it again today I used my GPS to check my speed and I wasn't even doing 50 and I was tachin 4 grand. Ok let's say my tach is screwed. Im telling you this thing is in third gear and its reving high it feels like a quarter mile car there is no way I can run this thing on the highway .I have no clue what the rear gears are but it sreamin also the tires are p 270 15
  20. There are many threads here on how to calculate the rear axle ratio without pulling the back cover. Use the search feature at the top of the page. Remember, if you have a open rear or non-posi, you must hold one of the wheels from turning as you proceed. Second, sounds like your tach might be wired for either a 6 or a 4 cylinder engine. You might want to check that also, TR
  21. badshifter
    badshifter
    Your facts are wrong somewhere. The calc. says you have a 6:5 something gear based on a 27 inch tire. Doubtful. On a personal note your so called attempt at humor is pitiful.
  22. Take the back of off the tach, or take the cup off. Now look for either some small dip switches or actual wires that need to be transfered/moved for the # of cylinders.
  23. All you need to do to determine the ratio is count the driveshaft revolutions vs one axle revolution.
  24. bulletproof1
    bulletproof1
    from tulsa okla
    pretty sure 4:56-4:88 is about the lowest gear you can get for that 10 bolt...id put a good tech on it to see for sure what the rpms really are.. yes gears have to be 'shimmed in" aka set up... shpould be pretty easy to find a good 3:00-3:55 gear set for it..have them installed by someone who knows how to do it correctly..
  25. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    There is soooo much bickering on this post...
    Just curious, What kind of car are we talking about anyway?
  26. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Id dump the 305 and put a 383 and call it a day,Or a worked small block......
  27. c.cwf
    c.cwf
    Pitiful is a reply from anyone on this post in regard to what ever type or humor.if you don't get/ or like it LOOK away.if you don't like it-it probably wasn't ment for you.but all this BOO HOOING is just sad let it go already try and be big boys - as for any one with good sound info. hats off to you -your good people and i'll buy ya a beer if I meet ya.
    FORD TOUGH WITH CHEVY STUFF
  28. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    Youve actually got all the info you need to do what you want. They told you how to figure out your rear gear ratio, that somepeople like 700r4s, and some people dont, and that some people dont like 305s ( its all personal preferance) and that its always easier to swap your rearend than a ******... All comes down to how much time and money you want to spend... And i guess you really are trying to make everyone mad with your last statement...
    Personally i like keeping gm gm, ford ford, mopar mopar, and hondas in a junk yard... What kind of car do you have? Just interested... I can help you get parts for a cut rate if you need anything.
    P.S.... Can i have a beer?
  29. c.cwf
    c.cwf
    No im not the type to try and upset anyone but the fact is I love chevy I own a ford and its filled with wonderfull chevy parts .its a 1929 Ford Model A sedan. Original frame boxed 2001 blazer rear.1991 chevy 305 and a 1977 turbo 350******. So I say ford tough with chevy stuff.smile im all about the love for the car don't matter to me what you have as long as you love it like I do.
  30. 1964countrysedan
    1964countrysedan
    from Texas
    what he said
