all geared up
Discussion in 'The Hokey Ass Message Board' started by c.cwf, Dec 31, 2011.
  1. gimpyshotrods
    gimpyshotrods
    What kind of tachometer are you running? Is it the kind that has a 4-6-8 switch on it? If it does, check that. The lowest gear found in a S10/15 rear axle is 4.10:1. If you had that, for it to be in top gear, at 50 MPH, spinning 4K RPM you'd have to be running about 14-1/2" tall tires.
    Ratio options for the 2001 Blazer were 3.42:1 (tag will say GU6) and 3.73:1 (tag will say GT4). There are two different axles that year, one with a 7-5/8" ring gear, and the other with an 8-1/2" ring gear.
    What the tach should read (not corrected for transmissive losses), based on a 27" tire is as follows:
    3.42:1 @ 50 MPH, in top gear: 2128 RPM
    3.73:1 @ 50 MPH, in top gear: 2321 RPM
    If you had a different year S10 axle, with the 4.10:1 gears:
    4.10:1 @ 50 MPH, in top gear: 2551 RPM
    If somebody changed the ring and pinion to a deeper one the lowest gears are as follows:
    7-5/8" ring gear: 4.56:1
    4.56:1 @ 50 MPH, in top gear: 2837 RPM
    8-1/2" ring gear: 5.57:1
    5.57:1 @ 50 MPH, in top gear: 3466 RPM
    The deepest practical gear that you would use on this axle, in a 4x4 rig, with 35" tires, would be 4.88:1.
    8-1/2" ring gear: 4.88:1
    4.88:1 @ 50 MPH, in top gear: 3036 RPM
    In any case, not 4K RPM.
    Since the TH350 torque converter does not lock up, there is a small amount of loss ***ociated with it. Your actual RPM numbers may be 50-150 RPM higher.
  2. Dapostman
    Dapostman
    Is the vacuum modulator hooked up correctly? If not, the transmission will stay in second.
  3. c.cwf
    c.cwf
    i think i got it ..THANKS TO ALL WHO ADDED SOME INFO .
  4. bobss396
    bobss396
    All you have to do is jack up the rear, spin a rear tire 1 time, see how many revs the drive shaft goes around, do the math and you'll be real close. I'll also 2nd the mis-wired tach thing. Some tachs have a switch on the back of them.
    Bob
