All time greatest engine?
Discussion in 'The Hokey Ass Message Board' started by exwestracer, Sep 29, 2008.
  1. Miller-Lockhart engine used in the LSR Blackhawk.....only one was built....
  2. teddyp
    teddyp
    sbc way cooler a baby hemi but they do look good
  3. jipp
    jipp
    on page 3 i think it was there was a sbc with hemi heads.. why did that not take off? the cost to produce was to expensive to make a profit?
    i think i remember reading thats why they stop making the hemi for a period of time. shrugs.
    chris.
  4. Deuces
    Deuces
    I'm not into Revlon 1400 watt blow dryers.. :rolleyes:
  5. Godspeed
    Godspeed
    The one that got me home
    Day after day
    When the chips were all down
    Couldn't afford the oil change
    I thanked God for the job, the food on my table, and the engine that kept running.
    If you know which engine it is, you don't need to say it to be true.
    If you don't know which engine it is, I pray that you never do.
  6. Deuces
    Deuces
    Ummmm...... You ever learn how to use a torque wrench??? :rolleyes:
  7. Deuces
    Deuces
    Those were prototype SCCA Trans Am heads for the Z/28 302 motor....
  8. pistis
    pistis
    from S.F.V
    The FireballV8 (nailhead)
  9. outlawsteel
    outlawsteel
    Ok personally I think the best engine for a hot rod is the one YOU can afford to put in it to try to beat the other guys opinion of what the best engine for a hot rod is. There arguement solved :D.
  10. Deuces
    Deuces
    For me it was chevys and fords that got me home.... ;)
  11. toolz1175
    toolz1175
    from IL
    Ummmmm yeah, so what's that supposed to mean?
  12. jimmygrrr
    jimmygrrr
    I would say
    1) flathead- because of all the history behind it and its use in early rodding.
    2) Chrysler Hemi- It's ********** in early NASCAR and later top fuel
    3)SBC- as much as I dislike it, they are easily acquired and easy to make a **** load of hp. Personally wouldn't run one in my car, but I can appreciate them.
  13. CutawayAl
    CutawayAl
    from MI
    Flatheads are like Harleys. If they are given enough exceptions/advantages they can still keep up with the pack. Heads up, not a chance.
    The SB Chevy was a landmark engine when introduced. Judged from that perspective it deserves recognition. It did have imperfections and shortcomings, you mentioned some of them. People seem to be less willing to talk about the weak points than the pluses.
  14. What's the big deal, Rich? It's not like that engine was a world-beater...oh, wait....:D
  15. LOL excellent points. I race a 900hp BBC, have run VERY powerful SBCs in the past; and I'm often had many of the same thoughts...
    Someone made an earlier point for the BB Chrysler, and if you look at it from an engineering (and racing success with the 426 Hemi) standpoint, that's hard to argue.
    Still, the decades of (needed :D) support for the SBC make it a tough choice to argue with...
  16. The chrysler hemi - hard to beat!!!
  17. CutawayAl
    CutawayAl
    from MI
    Hard to beat for appearance, and the engine was the best stock block for top fuel use, but nothing is perfect. Biggest down sides for a street car:
    - Heavy, especially for a lighter car.
    - Wide
    - Cl***ic hemi combustion chamber is more suitable for low compression supercharged applications than higher compression naturally aspirated.
  18. Gumpy1940
    Gumpy1940
    327 chevy and 49 mercury flathead!!
  19. budd
    budd
    SBC all the way, if this was a thread about the coolest then a Boss 429 would get my vote.
  20. Stevie Nash
    Stevie Nash
    You just proved a point you didn't think you were proving...
  21. Boodlum
    Boodlum
    Ford 427 3-valve hemi "Calliope" engine. Designed in 1965-66 for 1968 Le Mans upgraded MkIV J-cars (or K-cars). Design parameter was to build as short an engine as possible to fit in race car ch***is. Hillborn injectors cast monolithic with aluminum heads. Two in-block cams and, like flathead engines, each head has its own separate water pump.
    http://www.supermotors.net/registry/17894
