Projects Almost done with the 41
Discussion in 'Traditional Hot Rods' started by 41build, Jun 20, 2016.
  1. 41build
    41build
    Found a oil leak at the back of the Intake Mainfold....dam its the same leak in the same spot.... 1466470752261.jpg plugs were under gap from previous owner..[emoji1] 1466470797671.jpg
    Sent from my SM-G920P using H.A.M.B. mobile app
  2. sunbeam
    sunbeam
    I always glue the end rail gaskets in place with 3M weather striping cement.
  3. 41build
    41build
  4. 41build
    41build
    I see what your saying , i did 1/8 inch thinck got it tacky and sat my intake and tighten it, you can see bubbling out...think im gonna smear some silicone their and let it dry.
  5. squirrel
    that won't work...pull the intake and do it over again, 1/4" bead
  6. oj
    oj
    When I do the intake gasket I apply sealant on the end rail gaskets and around the ports etc of the intake gaskets on just one side of the gasket. I then set the intake on and start several bolts and hand tighten then let it set overnight, pull the intake the next day and check alignment of endrail gaskets etc and then apply sealant and set the intake proper. No leaks and endrail gaskets won't squirt out.
  7. squirrel
    I gave up on the end rail gaskets years ago....a 1/4" bead of RTV works but you have to be careful setting the intake down on it. I don't let it set up first, some guys do.
    41build likes this.
  8. This.... Once you get past the thought of no gasket, intake installs go much better...
  9. fordor41
    fordor41
    Ditto for me. Has always worked.
  10. oj
    oj
    I'll confess, I read the instructions on a FelPro intake gasket set. I figure, its their gasket best I do as they say.
  11. ^^^^^ Yes, and make sure that it is clean before you squirt the silicone on.
  12. 41build
    41build
  13. swade41
    swade41
    from Buffalo,NY
    Nice truck, once a gasket is crushed, it's crushed. I would get a new set of gaskets myself.
  14. 41build
    41build
    Yea i believe i will
