Projects Almost Funny - AWB Barracuda Funny Car Build
Discussion in 'The Hokey Ass Message Board' started by squirrel, Nov 27, 2017.
  1. squirrel
    There are a lot of neat things I could do, but I probably won't...such as spindle mount front wheels.
    I'm getting into "let's get this car built" mode now. It won't be as wild as lots of us hoped for.
    t-rod, belair and bobwop like this.
  2. oldolds
    oldolds
    It's about time you get in the garage and start building! Everybody here has built your car twice, in their heads!
  3. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    Make it fast, cool and most of all safe. The rest will take care of itself. It's always more fun to hop up a running, driving car than looking at yard art until it's perfect.
    Sent from my SM-G920V using The H.A.M.B. mobile app
  4. Hemi Joel
    Hemi Joel
    from Minnesota
    You need to check everything on those. Pressure test, Sonic the bores, width and fit of main caps and saddles, main and cam bore alignment, lifter bore alignment. Some of them were way off. Usually nothing a good machinist can't correct though.
  5. I have looked online for a reproduction Barracuda body can't find one. Anybody aware of someone making one?
  6. squirrel
    This block has had a lot of work done to it, all the stuff that Joel mentioned has been worked on. We'll see how well he did on it.
  7. DDDenny
    Sure you can!
  8. squirrel
    that's not a slider window, is it?
  9. DDDenny
    :rolleyes:
  10. gene-koning
    gene-koning
    The old dirt track guys around here would drill holes in the brake backing plates, and some went as far as removing any part of the backing plate that wasn't needed. The extra air helped lighten the load, and improved brake cooling.
    Have you figured out your front axle yet? Gene
  11. swade41
    swade41
    from Buffalo,NY
    My buddy built a 2 Lane clone and he said the slider windows were unbearable hot allowing no air movement inside the car. He lasted one season in a Buffalo N.Y. summer and put the roll up windows back in the car. 100_4516.jpg
  12. BuiltFerComfort
    BuiltFerComfort
    I’ve seen slider windows that use the stock window track and lift from the bottom, using a seat belt strap (wrapped around a cleat so you pulled down on the strap to raise the window) and some Velcro for fastening. You could adjust the window height pretty well.
  13. squirrel
    that's what I have in my Chevy, and what I plan to do to this car.
  14. AlexCold
    AlexCold
    from Yuma, AZ
    Excellent hope to see you there in my “new” hot rod.
  15. Hemi Joel
    Hemi Joel
    from Minnesota
    What will the bore and stroke be?
  16. squirrel
    60 over bore 4.25 stroke for a 496 is my current thinking.
    juan motime and racer-x like this.
  17. James D
    James D
    Will you still be doing the altered wheelbase/stretched nose thing? I hope so!
  18. squirrel
    Yes, I will.
    enloe, James D, loudbang and 2 others like this.
  19. FinnishFireball
    FinnishFireball
  20. Hemi Joel
    Hemi Joel
    from Minnesota
    That's a good combination. You can squeeze in more stroke if you want. Using a crank with Chevy 2.2 inch Rod journals improves clearance issues and gets you a bigger choice of rods.
    loudbang and bobwop like this.
  21. squirrel
    I think that's big enough for now. I was planning to use the Chevy rod size.
    There are a lot of things to learn about these engines.
    Reading and hearing about heads and looking at what folks are using, and what has which problems....I guess Stage V is the best setup. I'm also looking at the Mopar aluminum heads, although getting good information about the heads they are selling now is kind of difficult. I know they had serious issues with valve seats years ago...I don't know if they've fixed them or not.
    I'd kind of like to use sort of OEM parts, to keep it slightly more period correct (and keep costs down a little), if they will work. I'm kind of a minimalist, I like to do the most with the least, when I can.
  22. Hemi Joel
    Hemi Joel
    from Minnesota
    You are going to need close to 1000 horsepower that lives on the street. That's not a simple task, and still be a minimalist. You must be planning an overdrive/underdrive pulley swap? Vintage iron heads are pretty easy to come by, and they flow well with a bit of porting. But they are really heavy.
    In aluminum, Stage v is very nice, and the replacement heads look like vintage iron heads when you paint them. Don't try to buy them right from Stage 5. Tim banning at For Hemis Only is the best source. His cnc stage v replacement heads flow 470 cfm at .700 lift . Not cheap though. But maybe with boost, you don't need that a killer head.
  23. squirrel
    I'm not planning to open the valves real far. I think having high flowing heads is not really part of the plan. There's the problem of making the valve train live for lots of miles, and keeping lift, and spring pressure, at reasonable levels seems to help a lot.
    I don't intend to swap the blower pulley, since the blower doesn't really do anything when the throttle isn't open very far, as in street driving.
    Gary Reynolds likes this.
  24. I run 320 lbs on the seat. there are ways to fool the spring into thinking its stronger than it is. using ***anium valves is one way. manley makes hollow stem valves. they are lighter than stock but not as light as ***anium. they are cheaper than ***anium. having ***anium retainers and locks is money well spent. using a blower makes the situation more critical as the boosted air is pushing on the back of the big intake valve. good rockers also help reduce weight and deflection.
    Atwater Mike, D-man313 and loudbang like this.
  25. squirrel
    I'm shooting for a lot less spring than that...under 200 on the seat, under 500 open, is my wild guess. Not a lot of boost, or RPM.
  26. It's coming together.
    What HP are you shooting for?
    Trans and gears?
    What about weight?
    It's interesting to hear your estimates of what's required.
    just asking.
  27. Gotgas
    Gotgas
    from DFW USA
    I completely agree with racer-x, spend wisely on good locks and retainers. Those big and heavy intake valves are like barn doors.
    If this thing is still AWB, I'm in! :D
  28. squirrel
    I'm going to have to sit down and do a bunch of numbers regarding weight... I'd like to keep it under 2500, but I dont know if I'll make it. I'd like it to get into the 8s, with somewhere close to 1000 hp at the flywheel. Considering a 727, and 3.54 or 3.73 gears in the rear.
    I don't know if I can make it do that, but I'll give it a try.
    enloe, juan motime and Gary Reynolds like this.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A good journalist tells a story that captivates his audience. It's clear to understand that in the world of compe***ion one never show's their Ace in the Hole. [​IMG]
    catdad49 likes this.
  30. squirrel
    I expect I'll be running in Unlimited, several seconds slower than the fast cars. So it doesn't matter who knows what I'm doing.
    Hotdoggin DaddyO and Johnny Gee like this.
