Almost got into a fight over brake lights not working
Discussion in 'The Hokey Ass Message Board' started by BloodyKnuckles, Aug 17, 2005.
  1. BloodyKnuckles
    BloodyKnuckles
    So I replaced the hydraulic brake light switch and the circuit breaker. I checked the filaments in the bulbs they appear to be fine. What am I missing? Is there some other switch or fuse or something I am overlooking?
    By the way this is a '51 Plymouth Cambridge.
    Any suggestions would be greatly appreciated.
    Thanks,
    ******Knuckles
  2. Crease
    Crease
    Is it connected to ground? Do you have brake fluid? Are the wires frayed? I would bust out the multimeter and go to town.
  3. Derek Mitchell
    Derek Mitchell
    Power to the switch? Wiring good from switch to lights? Good grounds?
    I'm sure I'm missing something.
  4. Nocero
    Nocero
    9 Times out of 10 your looking at a bad ground.
  5. shoebox72
    shoebox72
    Does it have a turnsignal switch? power from stoplight switch goes through the turn signal switch before going onto the taillights. Are your turn signals working. It may not be the problem but it's an often overlooked trouble spot.
    Use your testlight to narrow down where you have no pwer.
    Billy
  6. Normspeed
    Normspeed
    I'm a new guy....I have a 53. Is yours 6 volt? Mine stopped working til I pulled the sockets and sanded everything with 120 grit. Especially the sockets where they ground to the housings. That fixed the grounds and they work good now.
  7. BloodyKnuckles
    BloodyKnuckles
    I will check for ground. Yes it does have fluid. Wires don't appear to be frayed. I have yet to learn or understand my multimeter enough to use it:rolleyes: .
    One thing I forgot is when I was changing the switch I wasn't careful and the wires touched the frame and sparked, Thats what prompted the circuit breaker changeout.
    Thanks for the responses so far so quick.
    ******Knuckles
  8. PONY
    PONY
    Use a test light at the switch. One (either one) terminal should be hot, if not your problem is from there back to the fuse block. If you have a hot terminal, jump the two terminals and the brake lights should work. If they don't your problem is from there to the lights, including lights, sockets, grounds ect. If they light up, you have a bad switch. Good luck.
  9. BloodyKnuckles
    BloodyKnuckles
    Yes it does have turn signals and they still work.
    Thank You,
    ******Knuckles
  10. BloodyKnuckles
    BloodyKnuckles
    Normspped,
    Thanks for the heads up and I did do this a few months ago to make sure all the lights worked then.
    ******Knuckles
  11. BloodyKnuckles
    BloodyKnuckles
    Pony,
    This is a big help which I will do.
    Thanks alot,
    ******Knuckles
  12. Hey Knuckles,
    Im bettin its the switch...I had a brand new one in my 3W.....it **** itself straight away. Used a mech one from Speedway, never had a prob since.
    Check the switch. Good luck !!
    Rat
