Almost lost it!!
Discussion in 'The Hokey Ass Message Board' started by lockwoodkustoms, Nov 21, 2007.
  1. lockwoodkustoms
    lockwoodkustoms
    Today I decided to take the 39 out for another drive only to have my right front wheel lock up on me around 20-25 mph. Man did that wake me up, when I got off the road achecked the car out and realized that it was my brake that locked up. So I went home and got a jack and other necessary tools required for the job. To my surprise the caliper bracket was missing two nuts and bolts which allowed the bracket to move. This ended up cracking the rear pad which wedged itself enoughto lock the wheel up. I am glad this happened at low speeds and nothing happened . I can say that I will be checking nuts and bolts from now on and make it a religous practice to apply lock tite to everything even if the have nylocks on them or not. I will not say who's kit I used for because this is my fault for overlooking the obvious. So be sure to perform regular inspection of your rides and to everyone have a great thanksgiving.
  2. chaddilac
    chaddilac
    use lock washers.... glad you're still here!
  3. HemiDave
    HemiDave
    from Austin, TX
    Wow, glad it turned out alright...coulda been ugly! Have you cleaned your pants in only one washing?
    Dave
  4. 40Standard
    40Standard
    from Indy
    been there, scary shit
  5. fugness
    fugness
    yep, scary shit, been there too, dam apprentice didnt tighten the wheel nuts
  6. Dirty Dug
    Dirty Dug
    That's another reason I like '40 Ford brakes, no calipers.....Happy you're OK.
  7. IRCOOTER
    IRCOOTER
    from Surrey
    holy crap! been there to sure makes brake fade look good. eh.:eek:
  8. Been there too and I don't care what anyone said--the rush sucked.
  9. butch27
    butch27
    You mean the Nylocs didn't work?
  10. tfeverfred
    tfeverfred
    Pre flight checklist.
  11. moses
    moses
    lock tight and a torque wrench moses
  12. lockwoodkustoms
    lockwoodkustoms
    I will tell you what I am not looking forward for anything like this to happen again . I will tell you though I am glad that I have a few fellow rodders in the nieghborhood who were their to help me get the car back home.
  13. Don't crack it up,before you get it finished!!!You're lucky. Could've been alot worse. Time for a check-up. Look everything else over.
  14. lockwoodkustoms
    lockwoodkustoms
    I am goint through the whole car and giving it a new look for next year. I will be tearing everything apart and double checking everything that is crucial. Hell I will double check everything.
  15. I'm doing the same thing right now woth my Merc. Not gonna drive it again without changing a few things I don't like.
  16. DE SOTO
    DE SOTO
    First lemme say Glad you O.K.
    Then lemme second the comment about not liking Disc Brakes.
    Buddy of mine about 2 weeks ago had about the same problem with his Rear disc brake, But when his bolt fell out the pad was riding on the inside of his 15X14 aluminum wheel, He has about a 750 hp big block Chev in a '65 Pick up....
    Did a BIG Top Fuel Burn out & the pad dug a groove and cut the rim in 1/2 blowing out the 33x21.50 M/T.
    Did someone say Disc Brakes are safer ??
    I'll stick with my 12" '41 Lincoln brakes Thank You ..
