Hot Rods Alt.Question
Discussion in 'The Hokey Ass Message Board' started by Bruce Fischer, Nov 15, 2018.
  1. dan griffin
    dan griffin
    How much belt wrap on the alt.pulley? Did the car come with a alt.? A larger pulley will give more belt contact.
    Bruce Fischer and chryslerfan55 like this.
  2. Boy, belair, I would of like to see a picture of that one!.
  3. Dan, I don't know what you mean by belt wrap? Yes the car came with an alt, but since the car sat so long I replaced the alt. when I replaced the water pump and fuel pump too.Thanks Bruce.
  4. Belt wrap.
    Bruce, in the picture above you can see that pulley #1 and pulley #3 have a large potion of the pulley with the belt wrapped around it. These pulleys are far less likely to slip under load than pulley #2 or especially pulley #4 that has very little belt wrap. This diagram is more likely for a serpentine belt setup but the same principal applies for any V-belt setup. The more pulley surface that has belt contact (belt wrap) the less likely it is to slip.
  5. sunbeam
    sunbeam
