Hot Rods alt spacer
Discussion in 'The Hokey Ass Message Board' started by sdluck, Apr 27, 2024.
  1. sdluck
    sdluck
    I have a gm alt which has a metric 10 mm mounting bolt but the bracket has a 3/8 bolt.I have been to a couple of alternator but having no luck locating the spacer they used to sell for this. I have made a temp one with shim stock . Any body know where I can purchase one. Thanks SDLuck
  2. DDDenny
  3. A piece of thick-walled pipe and some longer bolts work.
    Bob Lowry likes this.
  4. squirrel
    The piece you made from shim stock is probably as good as it gets...
    I think these guys don't understand what you're talking about.
    19Eddy30 and Johnny Gee like this.
  5. sdluck
    sdluck
    No they don't,3/8 is .375 10 mm is 3937 so the shim needs to be .187
  6. Sporty45
    Sporty45
    I think it's supposed to be .0187 if my math is correct.
    seb fontana and Johnny Gee like this.
  7. Jokester
    Jokester
    I still don't know what they are talking about.
    .bjb
  8. sdluck
    sdluck
    Yes my math is rusty like me
    brading and Sporty45 like this.
  9. squirrel
    When you buy a rebuilt alternator, they are all drilled for the 10mm bolt, but come with a shim stock sleeve installed in the 10mm hole that drops the ID down to 3/8". This lets the rebuilders stock one part number to fit two applications.
    Johnny Gee and 427 sleeper like this.
  10. sdluck
    sdluck
    Correct but none of the rebuilder here had one in san jose.
  11. Sporty45
    Sporty45
    It happens with age, ask me how I know :p
    brading likes this.
  12. Jack E/NJ
    Jack E/NJ
    from NJ
    > >Correct but none of the rebuilder here had one in san jose.> >
    Welcome to Walmart. Wrap too-small bolts to fit too-big boltholes perfectly. Start your own SanJose bolt-wrapping business for a $1.99!
    vtx1800 likes this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I have not seen that sleeve inserted into rebuilds in my area for quit some time. And you’re correct, the shim stock OP used is just the same as what I’ve seen before. They are crude looking, not exactly round but they did the job.
    To OP, it’s a sleeve, not a spacer.
  14. Richard L
    Richard L
    from Quincy, IL
    A spacer to take your metric to 3/8 can be bought at an alternator shop. It is a thin sleeve that can be slid into the alternator housing that takes the hole down for your 3/8 bolt. I've used them for years in my shop.
  15. sdluck
    sdluck
    I know what they are and have removed them on Install,I was a mechanic for many years.
    I went to a couple of alt rebuilding shops in san jose,no luck.
  16. brando1956
    brando1956
    Go to J & N Auto Electric.com. Look at "components", "spacers and mounting bushings" Last item on the first page.
    Have dealt with them before and was very happy with products and service.
  17. squirrel
  18. 19Eddy30
    19Eddy30
    from VA
    A Traditional/old-fashioned hardware store one that sells gun screws and brushes other little trinkets, if No access to lathe ,
  19. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    I just make my own with the appropriate piece of pipe and a hacksaw. A longer bolt to fit through the hole with a nut on the other side works good, too.
  20. seb fontana
    seb fontana
    from ct
    Ok why is .0187 a worry?
    The Chevy Pope and ekimneirbo like this.
  21. DDDenny
    Somehow my "thinking out loud" reached my keyboard.
    Not sure how long your bolt is, would one of the GM starter bolts with the knurled shank work?
  22. seb fontana
    seb fontana
    from ct
    Thats not the spacer OP is worried about. The bolt is .375 and the hole in alt is .3937, so needs a .009 wall sleeve. Why worry, don't know.
    The Chevy Pope, ekimneirbo and nochop like this.
  23. 19Eddy30
    19Eddy30
    from VA
    You can Krurl / dimple ping & easily get the 0.009 size , if No smooth shank , use a longer bolt with shank , Rethread further down shank , then cut to fit
    Or rap S.S / ext ,wire strain into threads ,,, there are quite a few ways to get to where you need ,,,,
    pprather likes this.
  24. sdluck
    sdluck
    The mount I made has the bolt going thru 3/8 first then thru the 10mm alternators knurling wont work and it can't go in the other way not enough room.With help from a few members,I need 500-12004-50 from J&N but the won't sell to me without an account. I am still working on it.Converts Metric Holed Housing To Standard 3/8 Hole.Seb your math is as bad as mine.
  25. sdluck
    sdluck
    Found it on E bay,had to buy a package ,I will now have extra's if any body needs one.
  26. seb fontana
    seb fontana
    from ct
    ""Seb your math is as bad as mine.""
    Well probably, I'm old enough. 10mm is .394, minus .375 is .019. Whad I miss?
  27. sdluck
    sdluck
    . 009 is what you posted
  28. Jack E/NJ
    Jack E/NJ
    from NJ
    Seb's correct. 0.009"+ sleeve wall thickness is .018"+ decrease in hole diameter
    Ken Smith likes this.
  29. sdluck
    sdluck
    Not sure how you came up with wall thickness
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    In essence, math was invented because it offered practical solutions to complex problems encountered by ancient civilizations.
    seb fontana, 427 sleeper and chicken like this.
