Hot Rods alt spacer
Discussion in 'The Hokey Ass Message Board' started by sdluck, Apr 27, 2024.
  1. sdluck
    sdluck
    it loose in my bracket.
  2. squirrel
    it shouldn't be loose once you tighten the bolt :)
  3. DDDenny
    I thought this was "no math Monday"!:mad:
    427 sleeper likes this.
  4. Jack E/NJ
    Jack E/NJ
    from NJ
    SEB said > > so needs a .009 wall sleeve> >
    Seb's referring to the 0.009 wall thickness of the sleeve or bushing needed to reduce the diameter of the hole by .0.018
  5. sdluck
    sdluck
    The shim need or sleeve needs .019 when I get it.
  6. 427 sleeper
    427 sleeper
    Sure seems like alot of fuss for less than 1/32 of an inch.
    The Chevy Pope likes this.
  7. pprather
    pprather
    .009 on each side of the bolt reduces hole by .018.
    Òr does your shim only wrap one side of the bolt?
  8. You not get the memo? This is "MORE math Monday" ;)
  9. seb fontana
    seb fontana
    from ct
    And here we are.:cool:
