Alt wiring
Discussion in 'The Hokey Ass Message Board' started by htrod, May 31, 2005.
  1. htrod
    htrod
    Can someone help with a wiring question. I want to put a chevy 3 wire int reg alternator on my Y block. I need to know how to byp*** the voltage regulator and still use the Idiot light on the dash. This is in a 1956 ford S/W.
  2. Apache
    Apache
    from FL
    bumpin' this..i need to know because the gen light is always on for me, even when the key is out of the ignition
  3. Bob Dobolina
    Bob Dobolina
    on an early (10-12si unit) take an ignition switched wire to one side of your charge light. Out the other side of said light and out to the #1 pin on the regulator connection. You will need a diode on the exciter wire to prevent feedback to the ignition switch.
  4. 55 dude
    55 dude
    google "gm alt wiring" and wiring diagrams will appear.
