Projects Altered Drag Car Build
Discussion in 'The Hokey Ass Message Board' started by whiteknuckle, Nov 17, 2024.
  1. mohr hp
    mohr hp
    from Georgia
    Good going. What do the Shop Cats think about it?
    mad mikey and porkshop like this.
  2. Roothawg
    Roothawg
    Altereds are gay....
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Fa
    La Lah
    La Lah...
  4. RodStRace
    RodStRace
    I know this was tongue in cheek, but it and your signature together are chef's kiss. ;)
    mad mikey, Roothawg and porkshop like this.
  5. Roothawg
    Roothawg
    You are correct sir.
    mad mikey, RodStRace and porkshop like this.
  6. whiteknuckle
    whiteknuckle
    from Dryden, NY
    They're happy when the heat in the shop is on
    Toms Dogs and porkshop like this.
  7. whiteknuckle
    whiteknuckle
    from Dryden, NY
    Took advantage of a snow free weekend to get everything blasted. Nasty job in the best conditions but even more so when it's 30°. Some things are definitely worth paying for.
    20241215_112008.jpg 20241215_111959.jpg 20241215_104321.jpg 20241215_104335.jpg 20241215_161445.jpg 20241215_161509.jpg 20241215_161617.jpg 20241214_121939.jpg
  8. AHotRod
    AHotRod
    So ..... what are you going to do with it?
    GlassThamesDoug and 49ratfink like this.
  9. SS327
    SS327
    Push it around in his garage and just look at it when it’s done. Same thing we all do.
  10. whiteknuckle
    whiteknuckle
    from Dryden, NY
    Wanted to maintain as much originality of the ch***is as possible so I wanted to locate the bellhousing off the existing frame mounts. I thought they looked similar to a '55 Chevy setup but shallower and they were.
    20241220_122806.jpg 20241220_115032.jpg 20241220_122458.jpg 20241220_122503.jpg 20241220_122647.jpg 20241220_122724.jpg
    Made some new brackets to bolt onto the bellhousing that corrected the angle, and spaced things up a 1/4" to allow me to fit in between the existing brackets without having to modify them. Moved things as far rearward as I could. The engine is a few inches forward from where I would have placed it if I had started from scratch, but figure a little more weight on the front end is not a bad idea with something this light.
  11. 1971BB427
    1971BB427
    from Oregon
    I liked it right out of the gate, and even more so as you move forward! I'll be watching how you go forward with it. I really love Altereds and G***ers. Pretty nifty!
  12. saltflats
    saltflats
    from Missouri
    Do you have a dustless blaster or did you hire it out?
  13. whiteknuckle
    whiteknuckle
    from Dryden, NY
    Hired out
  14. hipojoe
    hipojoe
    Im in... LETS GO!!!:p
  15. mohr hp
    mohr hp
    from Georgia
    Bite your tongue, Blasphemer!
  16. Roothawg
    Roothawg
    I did a very similar restoration on Cody Parr's altered the "Apache" back in the late 80's. It was a 23 steel bodied T with an injected sbc. It had a tree growing through the middle of it and the trailer. The car had orginally campaigned with a supercharged Caddy, but later switched powerplants.
  17. Stock Racer
    Stock Racer
    Very cool! Great that you are saving her. Looking forward to watching your progress.
  18. whiteknuckle
    whiteknuckle
    from Dryden, NY
    Got boxing plates mocked up for the full length of the frame. Tried to anticipate everything that will get bolted to the frame and welded in captured nuts. Also added some internal nuts on the boxing plates to accommodate clamps for brake lines, battery cables, etc.
    Took advantage of some sunshine to roll the ch***is into the driveway for epoxy primer. I wanted to get the inside of the frame coated prior to boxing. Will probably throw a little rattle can paint in there and try not to burn all of it off when welding the plates.
    20241227_102741.jpg 20241227_102747.jpg 20241227_111208.jpg 20241227_113447.jpg 20241227_143202.jpg 20241227_143214.jpg
  19. 49ratfink
    49ratfink
    wow, that's really something. was boxed tubing not available back in the day? why would you build a frame from Model A rails to go fast
    GlassThamesDoug and porkshop like this.
  20. mohr hp
    mohr hp
    from Georgia
    60-70 years ago, pre war Ford stuff was as common as dirt, because Henry taught the world about economy of scale. Fords outnumbered everything by a huge margin before GM caught up. Whole "worn out" cars could be had for s**** value, while new steel from a mill was expensive. I imagine the builder had ready access to an unwanted Ford A frame, for nearly nothing.
  21. whiteknuckle
    whiteknuckle
    from Dryden, NY
    I'm ***uming this was built in the late 50's, prior to widespread use of square or round tubing for complete ch***is builds. Based on my hundreds of magazines from that era, use of 20 year old p***enger car ch***is of all makes was pretty common.
    Use what was available for cheap I ***ume was pretty common. My dad, who was born in 1932, bought a 1915 Model T army ambulance for $15 with a few 13 and 14 year old friends to drive around. Eventually their parents and the cops found out and put an end to their fun.
  22. I'm gonna guess that he didn't have any water pipe lying around......
  23. whiteknuckle
    whiteknuckle
    from Dryden, NY
    Sure he did.... That's what the push bar is made out of
  24. mohr hp
    mohr hp
    from Georgia
    Ha!
    porkshop likes this.
  25. Bearing Burner
    Bearing Burner
    from W. MA
    Waterpipe was easily available but he probably liked living .
  26. Dave G in Gansevoort
    from Upstate NY
    Black iron pipe, used for gas pipe, was commonly used well into the 70s for roll cages for dirt track cars up here in the northeast. And it actually is not ****py material as everyone thinks. It’s a mild steel, usually 1018, welded pipe, made from HRS plate. It is not water pipe, typically similar material, but galvanized. The black mill coating is easily removed unlike galvanizing which isn’t, and will contaminate the welds and kill you if you breathe the fumes during welding.
    It’s on a par with 1018 HREW tubing strength wise, just slightly larger od, and schedule 40 has a thicker wall. BTW, many cars are still being built with HREW tubing, that meets many sanctioning organization’s regulations. The reason for better materials, say 4130, is to allow thinner wall thickness, saving weight. If you look at the stress-strain curves for various steel alloys, you will find that the Young’s Modulus is approximately 30x10^6 psi. This is an important material property in design calculations, as it is the linear portion of the curve. If the loads are kept in this range, the member being loaded will stretch elastically and return to original shape after the load is removed. Exceeding this point on those curves is plastic deformation, and the structure will not return to original shape.
    That point is the elastic limit, or yield point. As the materials get stronger, the elastic limit is greater as well as the ultimate load limit, where things fly apart, however the loading between the two points gets smaller. Higher strength materials are more brittle, while lower strength materials are much more ductile, deforming before failure. A handy feature for something like a roll cage in an accident.
    And as one of my old professors used to say, strength and ductility are mutually exclusive. Well, until you get to the modern super alloys, also called unobtainium $$$
  27. whiteknuckle
    whiteknuckle
    from Dryden, NY
    Spent the last morning of 2024 fabricating a mounting bar for shoulder restraints and getting it tacked into the roll bar and the first morning of 2025 getting all the boxing plates tacked in. A friend has offered to bring his portable TIG machine over to finish weld everything after the fab work is completed. Time to kick back and watch some football.
    20241231_111859.jpg 20241231_111909.jpg 20250101_132921.jpg 20250101_132928.jpg 20250101_132935.jpg 20250101_132947.jpg
    slayer, mad mikey, Just Gary and 9 others like this.
  28. guthriesmith
    guthriesmith
    Just found this thread. Very cool and I’ll be following along! :cool:
  29. duecesteve
    duecesteve
    It will definitely put that jetski ****eatin' grin on your face at the end of the track :)
  30. whiteknuckle
    whiteknuckle
    from Dryden, NY
    While I had the ch***is outside for blasting I noticed that the right rear axle housing looked bent outward of where it's rigidly attached to the frame rail. I had some bearing sleeves made up for the '55 rearend so that I could use my narrowing jig to see how bad things were off. The "good" side was off by at least 3/16", which was probably pretty good for a narrowing job 65 or 70 years ago. The "bad" side was so bent I couldn't even get the bare 2" rod through the housing. I'll ***ume the right rear wheel/tire encountered a wall or guardrail at some point in this things lifetime.
    I cut the good side through where it was originally welded when narrowed and cut the bad side as close to the framerail as practical. I plug welded in some thin wall sleeves with an OD to match the ID of the axle housing to help center where the tubes were mated and located the outer ends with the axle sleeves and centering rod. Called it a day after getting everything tacked in place.
    SS327, saltflats, Chucky and 6 others like this.
