Projects altering '30's dashez, lets see yours
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Nov 19, 2018.
  1. sloppy jalopies
    sloppy jalopies
    DSCN3462.JPG DSCN3460.JPG This dash is a closed car '38, matching the speedo and gauge cluster can be tough, 15 different combinations... '37 -'39 car and truck, dlx and std... also eliminates the fluid in a tube senders.
    I used a closed car, but Woodie / cabbie dashes better lend themselves to mounting in a '30-'31 closed car A... they taper down about 1/2" as they widen... no crank hole.
    I cut out both speedo and cluster mounting holes, moved the speedo to the center, filled in the gaps, will holesaw and mount 2 gauges centered either side of the speedo...
    Like a '35-'36 car, don't need to match the speedo, oil and temp beside the speedo, gas in the right kick panel...
    traded the first one with nashrodman, think it was a '39 car though...
    I also remove the speaker grill, fill with flat steel and mount a neat little $6 V8 flags emblem inside the stock speaker grill bezel... fits like a glove but forgot to take a pick... DSCN2881.JPG s-l1600...v8.jpg
  2. LAROKE
    LAROKE
    Work in progress on my '37 Chevy pickup, Deerslayer.
    Original dash with '35-'36 Chevy car glove box door which has ash tray and clock. The clock is a '54 Chevy truck clock. Steering wheel is a '41 Chevy car deluxe "spinner" wheel. Rubber shrouded marine push ****on, high on dash, next to glove box, is new horn ****on.
    sloppy jalopies likes this.
  3. sloppy jalopies
    sloppy jalopies
    yup... also like the 1942 hubcap hat...
    LAROKE likes this.
  4. NashRodMan
    NashRodMan
    "traded the first one with nashrodman, think it was a '39 car though..." Yep, and I haven't done a damn thing with it yet. LOL. Maybe someday.....
  5. chopnchaneled
    chopnchaneled
    from Buford Ga.
    Thanks for starting this thread, Trying to make my mind up on my 27 roadster.
  6. sloppy jalopies
    sloppy jalopies
    The '30-'31 model A closed car hotrod dashes are 41.25" wide... if your T is close then a '37 to '40 will work... HIH,
  7. sloppy jalopies
    sloppy jalopies
    '38 closed car, 1.75" exhaust pipe about 6" long, split lengthwise, used 1/3 of the pipe per side, then .5" was flattened on an anvil... makes what looks like a candy cane from the end...
    welded in to let the ends rollover smoothly... will buy soup ladles Wednesday to cut and form the upper corners... DSCN3464.JPG DSCN3466.JPG DSCN3465.JPG
  8. chopnchaneled
    chopnchaneled
    from Buford Ga.
  9. sloppy jalopies
    sloppy jalopies
    Dropped a $5.00 motorcycle speedometer in and drilled a couple gauge holes, sanded the edges and gave it a coat of cheapo spraybomb… a little like a '36 and '38's offspring.
  10. Dave Mc
    Dave Mc
    My 33 Dash insert , gauges inset by using exhaust pipe and added turn signal & high beam indicators
  11. sloppy jalopies
    sloppy jalopies
  12. sloppy jalopies
    sloppy jalopies
    Cut out the speaker louvers, filled and sanded it , retained the holes to mount its bezel...
    had [1] 289 with flags emblem... fits in the bezel ? hmmmmm.
    trimmed the outer edges [exhaust pipe] to better match the A pillar...
    H DSCN3495.JPG DSCN3496.JPG DSCN3497.JPG Had a glovebox door that had its clock hole hogged out to 2 7/8" diameter...
    I offset hogged it out to 3 3/8" for a tach... welded in a 1/4"-20 alignment stud at center to locate and support the dash...
    bowlingball likes this.
  13. Visionary pinstriping
    from amherst ny
  14. sloppy jalopies
    sloppy jalopies
