Technical alternate cap for Vertex magneto?
Discussion in 'The Hokey Ass Message Board' started by Paul, Jul 9, 2024.
  1. Paul
    Paul
    Editor
    I pulled my stock Delco distributor and replaced it with a Joe Hunt Scintilla based magneto.
    It fits and works great but the wire routing is less than ideal.
    it would be much better if the plug wires exited the cap four right side and four left..
    is there such a thing?
  2. Paul
    Paul
    Editor
    or straight up like this one but with eight posts instead of four.?
  3. None that I remember seeing. That would mean if there is, it's not common. :)
    Paul likes this.
  4. Fordors
    Fordors
    Only option I can think of is have it converted to an OXC with an external coil. Here’s the OXC cap, not the same look but it gets you some clearance if that’s what you need.
  5. jimmy six
    jimmy six
    Ford cap base and cap from Joe Hunt..his website shows 6 and 8’s
  6. Paul
    Paul
    Editor
    I'm not seeing it, got a link?
    Johnny Gee likes this.
  7. jimmy six
    jimmy six
    Joe Hunt Magmetos site > Categories on left side > caps > automotive > vertex …. View parts top 2 … they don’t show the 6 cyl cap but it’s available at parts stores (so is the adapter and 8cyl)
  8. Paul
    Paul
    Editor
    I must be missing something, all I see in that configuration are external coil caps.
  9. Paul
    Paul
    Editor
    the magneto and wire layout at present,
    final layout not yet settled on.
    kadillackid likes this.
  10. Paul
    Paul
    Editor
    another other issue yet to be worked out is tach drive,
    I swapped out the 1/4 sweep electronic that was working with the stock points distributor for a full sweep mechanical tach.
    not a big deal, just one more thing.
    kadillackid and loudbang like this.
  11. Hollywood-East
    Hollywood-East
    Not period, But a ****on cap Allen might allow the cable (tach)clearance..
  12. Paul
    Paul
    Editor
    yes, that is my thought too, it will need a little t******* on the hold down too.. or a counter sunk allen bolt.
    either will mean pulling the cable to adjust timing, again not a big deal..
  13. 427 sleeper
    427 sleeper
    I always thought that bowl of Spaghetti back there was one of the cooler parts of running a mag. 7mm wires do give a cleaner appearance.
    Is there a reason that you can't run the wires out of one side of the cap or the other, instead of the back? Obviously the front is out of the question.
    Paul likes this.
  14. Harv
    Harv
    from Sydney
    An old racing trick to stop misfiring was to modify the Vertex with the "big cap". I hunted this down a while back.
    The distributor cap used is Ford, though I only noted down the part number for the HEI distributor that it is robbed from (Cardone 84-2669), as per the image below.
    Cardone distributor - used with adaptor to fit Vertex to stop crossfiring.png
    I've never made the modification, but suspect someone here has. I think @lippy shows one here:
    Early Hemi Ignition | Page 2 | The H.A.M.B. (jalopyjournal.com)
    Cheers,
    Harv
  15. 427 sleeper
    427 sleeper
    It doesn't look like he has any room for that monster of a cap.
    Hollywood-East likes this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Not only that. How do you send the discharge from below to the plug wire terminals above?
    427 sleeper likes this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    I can't even imagine Paul wanting to run a modern looking cap on his otherwise period perfect car....
    lumpy 63, 427 sleeper, slayer and 3 others like this.
  18. Dave G in Gansevoort
    from Upstate NY
    Paul, I'm glad you're going to work this out. Another thing to plaigerize for the Whatever project.
  19. Why not rotate the Mag 90 Degs so the leads either come out the Left or Right hand side?
  20. jimmy six
    jimmy six
    Sorry, yes that’s what they are for…
  21. Hollywood-East
    Hollywood-East
    I personally, would run 7m wire's, An tight'n it up a bit an Roll!
    I pushed mine back just to see...
    You definitely have enough room...
  22. Harv
    Harv
    from Sydney
    Point taken. My bad.
    Would a shielding hood make the wiring neater Paul? Those are closer to period correct. Photos below are mine, to suit a six-banger.
    Cheers,
    Harv
  23. Oneball
    Oneball
    What about an offset magneto drive?
