alternator issue...help
Discussion in 'The Hokey Ass Message Board' started by convict, Nov 27, 2013.
  1. convict
    convict
    from laredo,tx
    Ok,just a ? I have a one wire alternator,mounted to the lower driver side of engine. The problem is that the back bolt to the alternator hits the vega box,so I decided to open the alternator n moved bolt position,would that cause a problem...everything looked to go back in its place,n bolt was moved over..thanks for help in advance
  2. BamaMav
    BamaMav
    from Berry, AL
    Shouldn't be a problem as long as the brushes went back into place. I've re-clocked GM alternators like that before without any problems.
  3. convict
    convict
    from laredo,tx
    Cool..thanks
  4. prpmmp
    prpmmp
    Should be able to take the 4 bolts out and spin it around with out taking it apart. Pete
