Alternator location
Discussion in 'The Hokey Ass Message Board' started by silvalms01, Jun 14, 2008.
  1. silvalms01
    silvalms01
    I have a Navarro flathead tri-power intake. What parts or pieces do I need to use to keep the alternator located in the center and not have to offset it?
  2. yorgatron
    yorgatron
    you meant to say GENERATOR,didn't you? :confused:
  3. 36tbird
    36tbird
    If you have an 8BA, I believe that the stock fan belt location will allow the alternator to miss the bowl of the forward carb. I have a 59A that I got 4 inch carb spacers for the front bowl to clear the alternator. You will have to shop for a belt that does not need a lot of vertical adjustment. Do a search on e-bay for the alternator mounts and pulleys if you haven't gotten one yet. The guy I got my carb spacers from is out of them so they are harder to find. Hope that helps.
