Alternator mounting options Early SBC??
Discussion in 'The Hokey Ass Message Board' started by Tugmaster, Mar 26, 2011.
  1. My early 283 does not have any threaded holes on the froward part of the head for a alternator bracket. If I want to mount an aternator and I was not running Ram Horns with the mounting bosses on them where else could I mount it? I was thinking of a low mount but I really think I will have hood/frame clearance issues. Any ideas?? Thanks, Todd
  2. t-rod
    t-rod
    A couple days ago there was a thread about converting a long sbc water pump to a short one and the alternator mount was addressed there. I'd post a link but I don't know how, a search will bring it up.
  3. Markgyver
    Markgyver
    There was a company is the last issue of Street Rodder that had a bracket that will work for early SBC. I had bought one years ago for a 283 that I was running. I will see if I can find it for you
  4. several places sell a mount that bolts to the front intake bolt on the passenger side and a water pump hole. puts the alternator in for hood clearance
    check out what Speedway , So-cal and Alan Grove has to offer
    here is the So-Cal , easy to make yourself
    Speedway , basically a 70's smog pump mounting bracket
  5. Please let me know if you find it. Thanks!! Todd
  6. Dipper Jr
    Dipper Jr
    from Indiana
    I got mine from Walden Speed Shop. Good people, nice parts and shipped quickly!
  7. Just took a peek at the Walden website. Thiers looks alot like the Socal one but less expensive. Thanks!!! Todd
  8. the Walden on the So-Cal brackets look the same because they were both designed by the same guy...jim jacobs
  9. GassersGarage
    GassersGarage
    If you run headers, there's a mount I used that attached to the front header mount.******* sells them.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes, a lil info on it. It uses the front 2 drivers side header bolts to attach the bracket. Its Z shaped and you mount the lower alt. bracket to it.
  11. Markgyver
    Markgyver
  12. Deuce Roadster
    Deuce Roadster
    Alan Grove makes a nice, sturdy bracket for not a lot of $$$ :D
  13. I have the Jitney Jake bracket for my generator on my 283. It is well designed and sturdy!
    -Brent- likes this.
  14. I went with the Jitney driver's side mount. Nicely made, well packaged, good instructions, fits with no issues. The neatest part is that I can point it out to you and say "Jake made that for me."
