Alternator off rear end....???
Discussion in 'The Hokey Ass Message Board' started by ModelAMafia, Nov 5, 2008.
  1. loudpedal
    loudpedal
    from SLC Utah
    Trust me dude, you don't have to remove the T/C or the flexplate. I've replaced it once just to see how hard it would be. It was easy.
    What would happen if the rear main let go??? ...please enlighten me.
  2. blackmopar
    blackmopar
    from fallbrook
    well, maybe we stole the thread, but seems like really good ideas for alternate alternator locations
    Von Rigg, that racemate is not cheap,but if you think about it - it does eliminate some other costs - water pump and alternator for me seperate could be $400.00, etc
    I wouldnt say it is the most tradiational looking piece, but think it could be a nice touch
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    True..you got a point there
  4. LabRat
    LabRat
    Thanks BENT , thats the one i was tryin to find ......
  5. theHIGHLANDER
    theHIGHLANDER
    Simple update ModelAMafia...get an underdrive alt pulley. Pretty common for Ford alts. Job done...have fun. Except the Optima. Is there such a thing as a "good" one anymore? All the cl***ic guys jumped on the 6 volt versions but they don't last.
  6. langy
    langy
    Yes your right, I made up an adjustable idler for mine but for some reason have no pics.
  7. retroridesbyrich
    retroridesbyrich
    from Central NC
  8. tweakman
    tweakman
    Lessee...more girl, R&P steering, Optima life: The R&P is Honda Civic, inside front crossmember (open on bottom for access), with a steering rod alongside frame rail to a double U-joint to the column. My Yellowtop is about 5 years old and seems to be doing fine. I use a Jabsco marine electric water pump, it draws about 5 amps.
    Don Ross of Garland, TX is my pro builder. He built the frame from scratch, did all the custom aluminum pieces and heavy lifting, and we ***embled the car in an unheated farm shed in the winter (you gotta love this sport).
  9. 8flat
    8flat
    I think that is a pretty cool idea. Making the mounts for the inner section might be a little tricky.
  10. split51
    split51
    from guthrie ok
    I called Race Mate about the wp/alt setup, The street version for a BB Chevy is $848.00. The only problem I see with it is I asked them about parts replacements and the parts are not an over the counter replacement if you lose an Alt while on the road. They said that the parts were specific to their alt.
  11. JRODHOTROD
    JRODHOTROD
    from Manor, TX
    So Yugo buy 2.
  12. Fordguy78
    Fordguy78
    I've wanted to do the same thing. Just a little worried about charging abilities.
  13. yoyodyne
    yoyodyne
    Racers slot the holes in the waterpump for fine adjustment. Some race pumps are made that way with jack screws in the top holes. Even the timing belt drive needs to be on an exact center to center dimension which requires adjustment of the pump.
    Another way is to make a 2 part pulley that can be adjusted for width with shims in order to adjust the belt. Otherwise you would need the pulleys to be custom made to fit the belt length.
