I have this issue and have no idea where to go next. Here are the details. Car 65 Pontiac. With a chattering Voltage Regulator. Alternator Vintage alt took a **** Replaced it with one off another car known working. (Chatter) Replaced that with a new replacement alt (chatter) Voltage regulator With alternator replaced the first time The Voltage regulator would chatter Unplug the alt with the car running and plug it back in all works fine(until you shut it off) then you have to repeat the process Replaced it with the one from the car with the known working alt/ and Voltage regulator. Still chatters. Unplug/replug procedure and drive. Replaced that with a new voltage regulator. Still chatters. However found out if you stall the car out with the clutch. To the point where it about dies it works the same as the unplug/replug method. Did any of that make sense and any ideas?
so, how have you determined that noise is really coming from alternator? tried running engine without alt belt on?
Quick check, try running a jumper ground wire between the alternator and regulator, if that stops the chattering, you just need to find the location of the bad/ weak ground. Posted using the Full Custom H.A.M.B. App!
Tried the extra ground no go. .......here's a vid of the chatter and let out on the clutch kill it down and it stops
Sorry here is the video. The chatter is the sound that sound like an empty power steering pump. It doesn't seem like much but it's pretty loud inside the car. Also I understand how this is supposed to work all except the resistance wire from the A term on the ign switch to the #4 term on the voltage regulator
Take the cover off and have a look at it while it's chattering. Maybe a close-up video would be helpful.
Update. Work has been crazy but this is where I'm at now. The chatter is coming from the field relay. And when you kill the RPMs way down it pulls together and starts regulating. I'm thinking that it may problem with the "sense" wire or a voltage drop problem in the main wiring harness creating the false full voltage field cutout at initial power-up. Does anybody know exactly where in the regulator circuit the condenser plugs in its not on any of my schematics?
Might sound stupid, but check the idiot light, it excites the alt. since you have replaced everything in the circuit that may be the problem. Also, make sure the new alt is not internally regulated
