Hot Rods Alternator Wiring Confusion
Discussion in 'The Hokey Ass Message Board' started by Trent R., Jul 27, 2023.
  1. Trent R.
    Trent R.
    Hoping someone can help me figure out exactly what I’m messing up with this alternator. It is a new TotalPro 7133 alternator that specifies that it is externally regulated. The car I’m working on has a separate switch controlling the starter and another switch controlling power to the coil. Shown below(excuse my artistic inep***ude) is how I currently have it wired, but in this configuration the alternator’s output continues to rise as the car runs and therefore the alternator itself gets pretty hot. The amp meter does not show a charge or discharge either. Frankly I’m stumped and any insight would be appreciated.
    Thanks,
    TR
  2. d2_willys
    d2_willys
    from Kansas
    Not so fast! The externally regulated alternators also have a two pin connector and power stud. See below:
    Ammeter is backwards, + should go to battery. - side to alternator, ignition switch, headlight switch, etc.
    You might want to check for the voltage regulator being grounded properly. If not grounded well, it will not
    regulate the alternator field. Note: The 2 pin connector to the alternator is flat in shape if it is an internally regulated
    alternator, but square shaped if externally regulated.
    squirrel likes this.
  3. squirrel
    No it is not.
    The difference is the two wire plug, notice the two terminals are parallel to each other, not in line with each other. The internal regulator type has the two terminals inline. This is not one of those.
    Mr48chev likes this.
  4. I should stick to my Ford stuff.... :oops:
    Center of the Galaxie likes this.
  5. Mr48chev
    This is one of the diagrams I have saved in my photobucket "alternator wiring "album .
    bubba55 likes this.
  6. squirrel
    then you'll not learn about the rest of the world, that would be sad....
    The GM alternators can get confusing, because there are so many varieties being made today.
  7. chicken
    chicken
    from Kansas
    Trent, the ammeter isn't reading because it's in the wrong wire. It needs to be in the wire from the alternator output stud to the battery, and all the power for the car's ignition, lights,radio and any other stuff will hook to the alternator side of the ammeter. That way it reads only what's going into the battery.
    Terry
  8. squirrel
    uh....the ammeter is SUPPOSED to read only what's going into or out of the battery.
    It indicates Battery Charge or Discharge. Not alternator load.
  9. Mr48chev
    This from one of my Text books I used when I was teaching. It reiterates IMG_9879 (2).JPG what Chicken said. Somewhere in my old **** from the 70's I probably have a diagram that shows how to wire up an Ammeter. I had the same setup on my T bucket in 1974 with an ammeter. The only power drawing thing on the car outside of the igniton was the head and tail lights so an ammeter worked fine.
  10. 24riverview
    24riverview
    May have the wires backwards on ammeter, just turn on toggle, should see a slight discharge. If not reverse wires. IMG_6045-1.jpg
  11. Mr48chev
    This is a simple farm tractor conversion to internal regulator alternator but you are only interested in the way the ammeter is wired. Screenshot (2017).png
