Alternator
Discussion in 'The Hokey Ass Message Board' started by magnuman, Mar 10, 2010.
  1. I want to use this alternator on a restoration I am working on.
    March says it's for Mopar applications. I am thinking about using it for a bbc. It is a single wire with an internal requlator, 100 Amp alternator.
    I am making my own custom brackets.
    Is there any reason it shouldn't work?
    March P95 alternator.
  2. bobscogin
    bobscogin
    No reason I can think of. You've already acknowledged the bracket issue in going Mopar to BBC.
    Bob
  3. 29nash
    29nash
    from colorado
    Pully looks like its for serpentine belt, that can be changed.
  4. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    They have a nice style too. It'll work well.
  5. Mr48chev
    Outside of getting the right pulley for the V belt I don't see any problem. I don't really think that it is that hard to swap it out.
    We are ***uming that you intend to run a V belt.
    You might get away with using the stock mounting bracket with just a spacer adjustment to line the pulley up with the other pulleys to get the belt straight. The bracket to adjust it might take a bit of fitting though.
    Years ago a lot of guys preferred the Mopar alternators for alternator swaps and they are as reliable as anything.
  6. KENDEUCE
    KENDEUCE
    Also ask "What if it breaks down in BF Idaho"?
    That's why I switched from 1wire to 3wire GM alternator
  7. sloorider
    sloorider
    nice looking unit thou, what mopars was it used on?
  8. paintcan54
    paintcan54
    Whats the matter with running a GM one wire, it's a bolt on no guess work, and works well? Just my .02
  9. Mr48chev
    Magnumam, outside of it just being flat pretty what other reason are you considering that particular alternator?
    I wouldn't be too excited about the "if it ****s out on the road" thing as like 440Roadrunner said, there is always a way around that.
    Most of the time I advocate going with pieces that can easily be repaired or replaced if they give out in "BF Idaho" but this time I don't see that as a real issue. The good thing about most alternators with a somewhat standard size case that you can McGiver something at most any parts house or wrecking yard that will get you home without a lot of effort.
  10. KENDEUCE
    KENDEUCE
    "BF Idaho" - - No offense intended, but to me it is far from home and sounds isolated.
    "1 wire alternator" - - I changed to 3 wire for two reasons: 1st it's hard to find a 1 wire regulator, and 2nd, I didn't want to put another gage in the car so I put an IDIOT light in. It must have the three wire setup to work.
