Technical Alternators......how big is yours
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Nov 11, 2023.
  1. Marty Strode
    Marty Strode
    On Flatheads in the Track Roadsters, since they are bare bones, I use a 35 amp Denso. IMG_0604.JPG
    V8-m and ekimneirbo like this.
  2. Don’t have a clue.
    but whatever it is, it works
    ekimneirbo likes this.
  3. blue 49
    blue 49
    from Iowa
    This small one is a mid-80s Suzuki Samurai application and is supposed to put out 55 amps. The only loads I have are lights, radio and ignition.
    Gary
    jimmy six, ekimneirbo and loudbang like this.
  4. Kerrynzl
    Kerrynzl
    Kubota tractor alternators are small enough that with a bit of work, can be stuffed inside an AC Delco generator housing
    SPECIFICATIONS: 30 Amp/12 Volt, CW, 1-Groove Pulley
    DESIGN: IR/IF
    VOLTAGE: 12
    AMPERAGE: 30
    ROTATION: CW
    PULLEY CL***: V1
    REPLACEMENT FOR or COMPATIBLE WITH KUBOTA:
    TG1860G 2 0.59L 00-05
    TG1860 3 0.72L 99-03
    G2460G 3 0.74L 01-05
    brandon, ekimneirbo and Budget36 like this.
  5. Harv
    Harv
    from Sydney
    On the avatar, a Bosch 120A alternator running into a sealed deep cycle gel-cell battery to fit into the limited under-hood space. The setup horrifies my local battery mob... apparently you are not supposed to use that type of battery the way I do.
    It works. Cranks over the 10.5:1 Chev without problem, even when doing extended compression tests on all eight. It runs for a week while I am home, then sits idle for three weeks. Runs happily in Sydney traffic, freeway, or north of 6000rpm at the track. I'm getting 5-7 years out of a battery. No signs of overcharging or damage.
    Interestingly it needs a throttle blip to self-excite the alternator each start up (won't self-excite at idle).
    Cheers,
    Harv
    ekimneirbo and INVISIBLEKID like this.
  6. nochop
    nochop
    from norcal
    jimmy six and ekimneirbo like this.
  7. A Boner
    A Boner
    Pretty low amp. Worked great until I put on a smaller crank pulley for tie rod clearance. Still works ok, except with lights on and at idle.
  8. brady1929
    brady1929
    Great thread.
  9. bobss396
    bobss396
    This is what I run too. With the electric fan (comes on once in a while) it draws 21 amps, I will upgrade it to a 95 or 100 amps once it ****s out.
  10. topher5150
    topher5150
    I got mine from a late 90s Taraus and the wiring harness from an early 00's Mustang V6. It's a 110 amp but I have a few extras that I'm going to use. Just gotta find a V pulley that fits.
  11. brandon
    brandon
    There's a small 1 wire samurai under there somewhere
