Aluminium Sand Blasting ( Dumb Question)
Discussion in 'The Hokey Ass Message Board' started by Harvey Mushman, Aug 25, 2006.
  1. Has anybody sand blasted their own aluminium valve covers and intakes? what grit and what medium do you use?
    Thanks
  2. Mike Rouse
    Mike Rouse
    I used crushed gl***, worked fine. Wash with mineral spirits after. Don't rub it with paper or cloth. They will leave fuzz on the thing.
    Mike
  3. chopolds
    chopolds
    from howell, nj
    Gl*** BEADS will actually close up the pores of the aluminum, and make it less likely to absorb dirt, while it cleans it.
  4. Dooley
    Dooley
    from Buffalo NY
    Another option is to take it to a transmission shop and let them soak in the cleaner they use for Aluminum ******'s, then see if it needs to be done.
    I 2nd the gl*** beading.
  5. Retrorod
    Retrorod
    we use #90 gl*** beads......clean up any dirt/grease first (just to help keep your medium clean)
  6. scootermcrad
    scootermcrad
    I also say gl*** bead. Leaves a neat looking finish too.
  7. Digger_Dave
    Digger_Dave
    Once it's nice and clean - do you coat (spray) a clear sealer to keep it clean??
  8. Retrorod
    Retrorod
    I usually powdercoat the stuff, most sealers and clear finishes don't last very well. I'm going to try some clear powder on some aluminum stuff to see how it works
  9. i use gl*** beads (60-100 on the bucket).
  10. KCsledz
    KCsledz
    Danny (warbozz) on the HAMB has a media shaker for stuff like this. Look him up he does good work. IT takes about 6 to 8 hours in the machine depending on the finish desired.
  11. Thanks for the info.
  12. JohnnyP.
    JohnnyP.
    gl*** beads again. this cleans it up real nice. havent tried powder coating it yet...
  13. If you were to powder coat. Can you ever get it off if you change your mind?
  14. tommy
    tommy
    Before
    After
    using gl*** beads from the air compressor store. Didn't know they were sized.
    I don't use it for polished Vcovers. It'll make it harder to repolish them. I have used it to remove paint from the fins but I tape up the sides to protect the finish. It workes great for stripping painted steel Vcovers though.
  15. Friend insisted on sandblasting his Porsche 912 engine cases, after the third engine failure/rebuild he was still getting sand out. My 02/100, sand is nothing but small rocks. (Dumb Questions are cheaper than Dumb Mistakes)
  16. 48fordnut
    48fordnut
    clear powder coating works well, better than silver. for me.
  17. akustom57
    akustom57
    I had an intake and valve covers smoothed then clear powder coated, one intake worked great, next one peeled and made a hell of a mess:confused:
  18. polisher
    polisher
    Alliance Vendor
    Napa Gasket remover and Loc***e "Chizel" both do a number on powdercoat.
  19. polisher
    polisher
    Alliance Vendor
    You can get blasting media as fine as at least 600 grit.
    That looks pretty tasty.
  20. Remember to use only clean media (gl*** beads, aluminum oxide, etc.) If you reuse anything you have used to blast rust off you will blast rust into the part you are trying to clean and end up with rusty aluminum.
  21. Cruiser
    Cruiser
    Harvey Mushman,
    :D Had some powder coated rims, we burnt the powdered black off, then powder coated them red came out great.
    Cruiser49:cool:
